SL/R230: Rear side window blows fuse 62 clicking in fuse box area why?
Why do I keep blowing fuse 62 on my left rear side when I push the window switch during the second sequence for the rear window? I get 6 or 8 rapid clicks emanating from the fuse box area behind the passenger seat after the fuse is blown. That sounds like a relay. 2004 500SL
I replaced the window regulator with motor assembly A2306700103 with a salvaged assembly about a year ago. Do you think there could be a pinched wire or wiring fault? When the regulator/motor goes bad can it short?
Unfortunately, the vario roof will not open completely because of the window failure. I need the top down to remove the leather-like covered interior panel above the assembly. It is a real pain to get to the assembly, much less to replace it.
I ordered a door window switch because some plastic has broken so the left switch will fall off when lifted.That left switch worked fine when you held it in place before the recent window failure.I doubt the switch is the culprit don’t you.That is another pain in the butt project to replace.You remove and partially disassemble the door panel to replace the window switch.If you haven’t already, you need to glue some door fasteners plus back into place, and replace some fasteners.
Why do I keep blowing fuse 62 on my left rear side when I push the window switch during the second sequence for the rear window? I get 6 or 8 rapid clicks emanating from the fuse box area behind the passenger seat after the fuse is blown<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->Exclaimer. That sounds like a relay. 2004 500SL
