SL/R230: 2004 SL 500 R230
I feel a vibration just before the car shifts gears. Gets better when everything warms up. I had the driveshaft rubber isolator disk replaced.
My mechanic said it was the torque convertor. Anyone have any experience with this?
If it is more load related, what is the condition and age of your engine mounts?
Sure, it could be the converter but lets rule out other things before you have the transmission removed.
Put the trans into "2" while driving at e.g. 20MPH and as the revs climb, note at what RPM you feel the vibration.
Next when Parked, leave the trans in Park and see if you feel the vibration as you rev the engine to that same RPM. If similar vibration then torque converter or front crank balancer has to be considered.
If no vibration, we can rule out front crank balancer, still possible torque converter, but now also driveshaft.
On Monday I'll look up the book time to replace the converter.
I would expect a bad crank balancer to not be noticeable until much higher revs. So, unfortunately it is sounding more like the torque converter. Internal blades or sections of the lockup clutch can come loose and cause an imbalance without obvious symptoms.
I'll lookup the book time for this on Monday so that you can compare to estimates you get. This is also an excellent time to replace the rear crank seal. Google "Mercedes m113 rear main seal" for more info on this.
Good luck and keep us posted.
decided to put in a second tube & it is working nicely. Just a tiny bit of shudder when cold. Operating temperature it is perfect.
I highly recommend this product.
