SL/R230: CD/Radio Hesitation - 2005 SL600
Old Jan 1, 2005 | 03:21 PM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
On my 2005 SL600 when I am playing a CD or radio and the roof is either opened or closed just before the final moments of the opening or closing the CD or radio hesitates.
It is almost like at the final stages of the opening or closing of the roof top that there is a little extra power needed and this draw causes a slow down or hesitation in the playing of the CD or radio.
I was wondering if anyone has experienced that problem and if they haven't and you have a 2005 SL600 could you please try to create this situation and see if the CD or radio that is playing hesitates. The CD and radio hesitation would be just before the final stage of the roof either opening or closing.
Thanks and Happy New Year to all.
Old Jan 1, 2005 | 06:29 PM
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
I believe it is the audio system automatically compensating for the change in ambient noise when you open/close the roof. It is normal.
Old Jan 1, 2005 | 06:33 PM
Never did that on my 2003 and 2004 SL's. I also did it in the garage and the sound is minimal.
Not sure you are right. We need someone with a 2005 SL600 to check their car. I could see a change in the sound level but we are talking about same sound level, just a slight hesitation.
Old Jan 1, 2005 | 10:16 PM
JackStraw's Avatar
This is from mbusa.com under specifications for the SL600:
Bose® Cabin Surround ™ multichannel digital sound system features: 8 speakers, including a dash-mounted center fill speaker and a 4x6" woofer, Cabin Surround sound architecture, with independent front and rear channels for a 360° sound field and a proprietary channel assignment algorithm for a balanced, accurate surround-sound experience for playback of audio CDs and optional SIRIUS Satellite Radio2 at each seating position, Bose Centerpoint™ signal processing, which processes stereo and matrix surround CDs to five independent channels, delivering a multichannel surround-sound experience, even from conventional stereo CDs. Bose AudioPilot™ digital processing, which monitors sound within the cabin and helps compensate for unwanted ambient noise with no perceived change in audio volume.
This link will take you to the Bose website that describes AudioPilot:
http://www.bose.com/controller;jsessionid=BXg461YMqb9JCJGFP4svDrWTJKPf ljMhmGn22lTHXyBN2F6pDXdw!1735365011!736317803?even t=VIEW_STATIC_PAGE_EVENT&url=/automotive/innovations/audiopilot.jsp&pageName=/automotive/innovations/index.jsp
Old Jan 1, 2005 | 11:12 PM
I understand this feature and what this spec and article are saying. I think you would see a lowering or raising of a sound level and not a hesitation.
If this hesitation were due to this feature it would be happening all the time when sound levels change. That is not what is happening. It only happens at the end of the cycle of the opening and closing of the roof.
With all due respect, I do not believe what you are saying has anytihng to do with this issue which may or may not be normal for this car. That is what I am trying to find out.
Think about it, if this hesitation were due to ambient noice the stereo would be hesitating all the time and that would be an impossibility from a quality point of view.
Thanks for the idea but what you are suggesting, in my humble opinion, is not the cause of the problem.
Old Jan 1, 2005 | 11:42 PM
tiggerfink's Avatar
SL500 and A-CLASS
LovingSL600,
Is your hesitation a slight pause of silence?
Old Jan 2, 2005 | 12:07 AM
JackStraw's Avatar
What you are experiencing happens in my car as well and I attribute it to the AudioPilot. The AudioPilot was changed for 2005 and that is why you might not have heard this "hesitation" in your '03 and '04.
I think the AudioPilot is set to recalibrate on the opening/ closing of the roof. The 500 msec delay you hear is the system recalibrating. AudioPilot does not recalibrate for minor changes in ambient noise such as normal conversation. If it did, it would be a pretty worthless feature. On the other hand, going from top down to top up (or vice versa) is a pretty big change in the noise level, and probably worthy of a recalibration (if you buy what Bose says).
Could I be wrong? Sure. Do I care? No. Does the delay bother me? No.
If it bothers you, call the service department on Monday and get to the bottom of this. You could enlighten all of us with what you learn.
Old Jan 2, 2005 | 12:15 AM
Originally Posted by tiggerfink
LovingSL600,
Yes.
Interestingly, I kinda played with things and found out if you only open the roof half way and then go to close it then the slight pause of silence in the radio or CD does not happen. If you open the roof all the way it happens both when it is at the end of the cycle of being fully opened and then again fully closed.
Wonder why it does not happen if you only open the roof half way and then decide to close it?
Old Jan 2, 2005 | 12:17 AM
Jack,
The way you have explained it this time I do understand and agree it could possibly be the recalibration at that point. That would make sense to me.
I only care if it is broken otherwise, it is fine.
Old Jan 2, 2005 | 10:04 AM
WIldcat465's Avatar
2007 CL600
Jack,
My car does the same. It's as if the volume dropped for 1/2 a second or so as the roof neared it cycle end.
Old Jan 2, 2005 | 11:04 AM
Originally Posted by WIldcat465
My car does the same. It's as if the volume dropped for 1/2 or so as the roof neared it cycle end.
Hey, thanks Wildcat. It is nice to know my car is not broken.
I did also notice that they eliminated the A/C bursts of air buttons on the middle top of the dash.
Too bad, I rather enjoyed that feature.
Old Jan 2, 2005 | 01:01 PM
WIldcat465's Avatar
2007 CL600
I didn't have my '03 long enough to read about/use that feature and if you hadn't asked your question about the radio I probably would not have been in the 600 for days. My wife just doesn't drive it. I did manage to take it out this morning to get the paper. I had surgery last week, so it was a little difficult to squeeze under the steering wheel, but once I got in all I could do grin.
Our--errr, I mean my new CL500 is a little more comfortable and spacious--it also has all options--except for the V12. My wife is so selfish, I can only drive her car when she wants to be driven around.
By the way, I wear the pants at my house.
Old Jan 5, 2005 | 01:49 AM
Spoke with my mechanic today. The SL has two different antennas. When the top goes up and down the car switches from one antenna to the other.
That is what is causing this slight pause in the stereo unit.
Old Jan 5, 2005 | 01:53 AM
vraa's Avatar
Shouldn't do that for the CD though.
Old Jan 5, 2005 | 02:00 AM
So funny, that was the first question out of my mouth when he told me that. What he said was that it is the switching mechanism itself that causes the split second delay in the command module, not the actual change in the signal so as long as any speakers are on, no matter what is playing, you will hear it.
Old Jan 5, 2005 | 02:01 AM
vraa's Avatar
Ah I gotcha. Makes sense now. Stupid electronics.
