SL/R230: Offset on these SL rims?
Old Feb 13, 2005 | 02:26 PM
breastroker's Avatar
2003 C230 K , 2001 ML320
Anyone know the offset of these rims? Mercedes Wheel Part# Front: B6 647 4081 Rear B6 647 4083
Attached Thumbnails Offset on these SL rims?-front-b6-647-4081-rear-b6-647-4083.jpg
Old Feb 13, 2005 | 04:40 PM
jasab's Avatar
SL500 '05
Love the look of these.
Be good to see the photos when they are on the car.
Old Feb 13, 2005 | 08:55 PM
Here is another wheel off the 2004 SL, I found out these have ET of 30mm front, and 33 rear. So I would assume the chrome one in the first thread are close to this offset.
I intend on having the existing axle flanges redrilled for 14 mm wheel bolts like the later S class has. Using a 20 mm hubcentric spacer this would put the offset closer to 10, which is appropriate for a 1969 300 SEL using 18 inch rims.
I would prefer to use the front 8.5 inch wide rims on all four corners, the rear 9.5 inch wide rims are a little much. The SL tires are also way to wide, probably go with 225/40/18 in the front and 245/35/18 in the rear.
I plan on rolling all the fender well lips. I may only be able to get a set of the chrome SL rims, which means I would probably need to have the inner rear fender wells enlarged with new tubs.
