SL/R231: Battery Tender
Any reason I should not be attaching a battery tender?
Thks
I opened up the hood to SL550 and it isn't readily visible. Is it in the trunk?
I feel dumb asking this and the manual isn't very clear.
I once hooked up my batter tender's w/o hassling car battery's terminals.Just pop up the hood and search + - .
I believe your manual should cover about it
Used to have our SL's parked for 4 months at a time and they always started fine. Batteries probably lasted 3 years or so.
My take is simple and it may sound a bit sarcastic. If a car can't sit in the garage for a month without being tended, it's really not a car I want.
I did hook up the battery tender to the battery in the trunk.
Took 48 hours to get a green light on the battery tender.
Will not keep the tender hooked permanently but thought it was good idea after almost 2 years with little use and mostly stop & go traffic.
Typical batteries for MBZ are 700 AH typical size car battery (size 37) or 900 to 1000 AH for the larger battery for the diesels (sizes H8 or 49). Just Google the model and brand of your batter to get its AH and CCA ratings. The AGM batteries with valve charge very quickly. It's the sealed gels that need a slow charge. Car batteries don't do well with deep discharge nor high temperatures, and IMHO the AH are either vastly over rated, under ideal situation and for a brand new fully charged battery.
MBZ has a warning not to charge the battery over 14.8V while connected to the car. Most battery chargers will go over 14.8V and some will go higher than 16V.
I just am out of a Masersti that had a very simple hook up.
I really can't figure out where this is on the SL
As long as you drive it at least once every couple months, the car's charging system is all the battery tender it needs .
Mine sits for 2-3 months over the winter. Never had a problem. Motorcycles may discharge in that time, but a car battery is much larger and generally engineered for much colder climates than motorcycle batteries are.
