SL/R231: Wheel fitment question
Mercedes CL550 w Rohana RC8
I have come across some 20" S63 OEM AMG rims with tires. I would like to use them on my 2013 SL550 that currently have Staggered 19"rims 8.5" front and 9.5" Rear rtims.
The 20" rims are staggered the same 8.5"front and 9.5"rear with ET 35 both front and rear. The rims currently has 255 and 275 tires. Will this configuration fit my 2013 SL550.
I currently have Rohana RC8 9 inch in front ET35 255 35 20. 11 inch rear ET35 275 35 20. Looks very solid, but my front rims have been bent & only replacement i found was rohana et20.
Instead et 35. Can et20 fit in front & what should i do with rear ET35? Should i add a 5 or 10mm spacer in rear? What advice would u give?
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/0312231818_hdr_b675654511af5462e353aeb3e93fda5697d2f7c7.jpg)
I am replacing Rohana RC8 9 inch front et35 with et20. Only pair i could find. Just not sure if i should add spacer to rear et35 if so which? 5mm or 10mm? Thank you for any advice. Currently front 9 inch wheel et35 255 35 20 & rear 275 35 20 et35 11 inch wheel.
