SL/R231: Park (P) Selector button problem
Now you have me confused!😊
Last month I turned off my SL in the driveway and started looking at my phone to return a text and the car rolled into the garage door.
They make “skins” for a lot of the steering wheel buttons and other Mercedes buttons, but oddly, no PARK button that I can find….
like these:
Anyone own a Honda Accord they can go measure? 😀
that P button (at the top) looks pretty close
I think it may be more self inflicted by overzealous detailers or exposure to moisture/cleaners or other fluids. It always seem to be right at the outer edges of the P right where the bonding would break down from chemicals or fluids. I find myself rarely putting my finger on the P when I hit that button. It’s pretty wide.
Anyone familiar with how this thing comes apart and how I go about replacing it? Thanks in advance.
Seems to me if you started jumping out the car with the car in drive you could make a mistake if you every drove a traditional trans again and forgot to shift to park. I’ll just keep manually pushing the P, but to each his own.
- My 2013 also had the peeling P button issue. I looked on ebay for a replacement in good condition, but found you have to buy the whole shifter assembly. The SL assemblies in good condition were around $300. More than I was willing to spend. I found a SLC assembly for $75 that looked identical. After buying it and taking it apart to determine how to make the switch, I found that the button will pop out without disassembling the whole shifter surround. I painters taped the lower edge of the shifter surround on my car to protect it and then used a box cutter blade to gently pry the button up and out. Popped the replacement in and was good to go. 5 minutes.
https://www.ebay.com/itm/37665436575...3ABFBM0ISAj8Vm
