SL/R231: Auto trunk open/close when freezing temps
Old Dec 24, 2021 | 07:20 AM
JettaRed's Avatar
Veteran: Army
Anyone have problems with the automatic open and close feature on the trunk lid when the temps are freezing out? Eventually it will close and latch, but only after a couple of tries. And opening also needs manual assistance. Later, when temps warm up (or the trunk has been accessed several times) the problem disappears.
I want to make sure the problem isn't some imminent failure of the mechanism. Also, is the trunk partition supposed to retract automatically when opening the trunk with the Vario roof down?
TIA
Old Dec 24, 2021 | 10:23 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Some have replaced the gas filled struts when this problem arises with success.
Here is a link….
Amazon Amazon
Old Dec 24, 2021 | 10:26 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
That sounds like an issue with the support struts.
They could just be weak or the oil inside them is thickening. Freezing temps in Stuttgart, may be different than freezing temps in Alaska. 😄
Only on the 2017+ Facelift cars.
Old Dec 24, 2021 | 08:25 PM
JettaRed's Avatar
Veteran: Army
I'm pretty sure freezing is freezing wherever you go. Somewhere around 32 degrees Fahrenheit.
Old Dec 24, 2021 | 08:27 PM
JettaRed's Avatar
Veteran: Army
Here is a link….
https://www.amazon.com/Mercedes-Conv.../dp/B0859Q71G5
Thanks. I went with the Stabilus ones as they are the OEM for Mercedes.
Qty (2) Stabilus 4B-908472 Fits Mercedes SL Series 2013 To 2019 Convertible Trunk Lift Supports (amazon.com) Qty (2) Stabilus 4B-908472 Fits Mercedes SL Series 2013 To 2019 Convertible Trunk Lift Supports (amazon.com)
Old Dec 24, 2021 | 08:47 PM
Haha, As a Californian anything in the 50’s is “freezing” 😀
Actually metal and rubber expansion/contraction rate and oil viscosity is directly correlated to temperature. HOT or COLD
Hence a part like those support strut’s, which contain oil internally, rubber seals, and steel rod will be MUCH stiffer in MINUS-60F Fairbanks Alaska than it would be in pleasant the Stuttgart at 30 degree F. It’s Basic Engineering ( first clue is your trunk has issues when it’s COLD). Colder it gets the more issues it would experience. Just swap them out you’ll be good to go. 👍
Gas Spring Tech As a rule of thumb, gas spring force increases by approximately 3.5% per 10° C temperature increase and reduces accordingly when the temperature falls.
Old Dec 25, 2021 | 07:06 AM
DrMongo's Avatar
2013 Sl550, 2012 CTS-V coupe, 2015 Grand Cherokee, 2014 Ram 2500
Actually guys, there is a thread elsewhere on the forum regarding this exact issue. It references replacement of the lock mechanism in the trunk lid. There is apparently a microswitch in there that is lubricated. The lubricant gets thicker with cold temps and prevents the switch from actuating properly, giving these exact symptoms. Recently acquired a new lock mechanism online for $230. Have not yet installed it. I am fairly confident however it will take care of the problem
Old Dec 25, 2021 | 09:06 AM
Another Car's Avatar
SL 550
Can you link the thread regarding this issue?
I can understand how a "bad" piston may prevent the trunk from opening but I don't see how it would stop it from closing. If it is weak then there would not be much resistance upon closing. Just an off the cuff thought. I Would think a defective "latch" would allow it to not close. BTW, I have had trouble with my trunk not closing but because the car is in storage for the winter I'll deal with it in the spring.
Old Dec 25, 2021 | 10:15 AM
Chances are the micro switch at the lock would store a code that could show up in XENTRY.
As far as the support struts go, with lower temps I’m thinking stiff, as in friction. The charge in the strut not being able to overcome the friction in the seals and thicker oil. Not necessarily weak.
But lock is definitely a possibility too as well as multiple issues (lock and struts) converging at the same time.
Strange things happen to cars in the cold 🥶
Old Dec 25, 2021 | 01:09 PM
DrMongo's Avatar
I do not have that link. I was browsing the forum when I found it. I can and will post the part number for the part. There was a stored code but it was a generic “malfunction” code for the trunk operation according to my independent shop. I will be installing soon and will update.
Old Dec 25, 2021 | 02:25 PM
DrMongo's Avatar
Part #A 231 750 00 85
Old Dec 25, 2021 | 07:47 PM
JettaRed's Avatar
Veteran: Army
That sounds a little more logical. However, the strut shocks were $50 and worth having on hand anyway.
Old Dec 28, 2021 | 11:00 AM
Thats why I think you MAY have multiple issues. Opening (lifting) of trunk is performed by the support struts and latching by the lock.
Scanning with XENTRY will reveal any stored codes for the latch. Typically it will show a hardware part number and software revision number. The micro switches in these cars will store a code. Even the speakers show up in XENTRY!
As I mentioned earlier, strange things happen to cars in the cold 🥶
Below is a an example window switch code that was stored in a car.
Old Dec 28, 2021 | 11:27 AM
JettaRed's Avatar
Veteran: Army
Well, it's been warmer lately and I've had no problem. I'm going to keep an eye on it and try to notice when there is a problem versus not. Thanks for the advice.
Old Dec 28, 2021 | 11:34 AM
Intermittent and temp related electrical issues are among the toughest to track down.
Good luck, and follow up if you find a definitive cause. 👍
Old Jan 5, 2022 | 11:52 AM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Just replaced my struts with the Stabilus ones that JettaRed suggested above. Absolutely the easiest repair I think I’ve ever made. Literally less than 5 minutes and under $50. Have no doubt that it would have been well over $100 at the dealer.
Old Jan 5, 2022 | 12:13 PM
Did it solve your problem?
What were the symptoms?
Old Jan 6, 2022 | 01:11 AM
SteveL1's Avatar
Trunk lid would not stay up in temps below 45-50 degrees. Yes, it fixed it as the temps here have dropped in the 20’s - 30’s and now have no issues.
Old Jan 6, 2022 | 03:31 AM
JettaRed's Avatar
Veteran: Army
Closer to $300. Or at least that's what a dealer quoted the previous owner of the 2004 SL500 I had, and that was essentially the same level of effort.
Old Jan 19, 2022 | 10:47 PM
jmonty21's Avatar
2003 SL500, 2013 SL550, 2018 GLE 350
Thanks to this forum, I now have a trunk that opens and closes properly in freezing weather. Replaced the struts with new ones purchased from Amazon from the post above and issues are gone. Thanks to all who have posted.
