SL/R231: Rotors and pads.
Old Sep 19, 2022 | 01:40 PM
NSAMG's Avatar
AMG GTR
Rotors and pads.
I just purchased a 2013 AMG SL63 for my wife, she loves it. There is a squeal when braking. I’m wondering where you guys are getting your pads and rotors from? Thanks.
Old Sep 19, 2022 | 01:58 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
front or rear?
if they are OEM they like to be “used” hard regularly. It could be a lot of other things though. Try re-bedding the pads with a few “abrupt” 60-0 stops and see if it improves.
Sometimes aftermarket pads make it worse….
Old Sep 19, 2022 | 02:26 PM
NSAMG's Avatar
AMG GTR
Rear. With less then 20000 km
Old Sep 19, 2022 | 02:40 PM
Rears have two guide pins that should be properly greased, (be sure it’s hi-temp caliper grease) I’ve seen them come out pretty dry before….
If you’re doing the service yourself, check those aren’t bent or anything too. Along with making sure the stainless retaining clips are clean and undamaged.
Honestly, with that little mileage, the rotors are probably glazed a little from gentle driving habits, and need to be re-bedded if they’re that new. I believe those will be TRW pads (from the factory) which are a relatively hard semi metallic compound.
I’m going to guess they didn’t make noise when you first got the car right?
Old Sep 19, 2022 | 03:50 PM
NSAMG's Avatar
AMG GTR
Correct, no squeal when I first drove it. Thanks for your info. I will pass it along to the mechanic checking the brakes.
cheers🍻
Old Sep 20, 2022 | 08:46 AM
JettaRed's Avatar
Veteran: Army
Pads and rotors may be a little tough to find. I got my rotors from fcpeuro.com and my pads from rockauto.com.
The pads I use and like a lot are:
DYNAMIC FRICTION 1600168800 {1600-1688-00} 5000 Euro Ceramic
Seems like for your car, there may be iron rotor and ceramic rotors. But here's the link.
Front: https://www.rockauto.com/en/catalog/...brake+pad,1684
Rear: https://www.rockauto.com/en/catalog/...brake+pad,1684
Old Sep 20, 2022 | 12:54 PM
griza's Avatar
2006 CLS55 AMG Sold 2010 E550 Coupe totaled by mechanic, '13 SL550 I totaled it, 2017 SL63 current
High performance brakes like you have on you SL63 tend to squeal and often need to be bedded in. As mentioned, find an open road and do a few hard 60-10mph stops. Then drive a bit without touching the brakes. That should eliminate the squealing.
Old Sep 20, 2022 | 08:11 PM
ram_g's Avatar
R231 SL63 & R129 SL500
Precisely as others have said. I too have a 2013 SL63 (welcome to the club, they are awesome machines!) and the brakes are simply oversized for “normal” driving. This car is my daily driver, so every couple of weeks or so of civilized commuter driving the brakes start squealing like banshees. Then I have to purposely drive like a hooligan and brake like mad a few times, at which point silence ensues. A couple of weeks later, rinse and repeat.
My conclusion is that normal driving causes a bit of glaze on these underutilized pads which needs to be purposely knocked off. Nothing really wrong with the brakes at all.
Old Sep 22, 2022 | 07:51 PM
JettaRed's Avatar
Veteran: Army
"Hooligans" and "Banshees"! Where you from?
Old Sep 22, 2022 | 08:59 PM
ram_g's Avatar
Umm…Texas? 😁😂
Old Sep 23, 2022 | 09:46 AM
Streamliner's Avatar
I’m just curious: For a non-AMG R231, what would one expect to pay for all new factory pads, discs & calipers?
Old Sep 23, 2022 | 11:52 AM
Factory disks and pads, I would think one would expect to pay about $875 or so, per axle at the dealership.
Haven't looked at caliper availability lately, but can tell you a dealership ended up buying my used calipers because of supply chain issues....
I would think that would add about $500. per wheel (list price) so $2k + $1750 (roughly)
I would go to an independent and use Brembo rotors and pads to save some money vs. mercedes factory parts. Quality is comparable and should be cheaper.
Getting ready for an R232?
Old Sep 23, 2022 | 12:36 PM
Thanks very much. As you may know, I put CCB on my 2019 SL450. I did it when the car only had about 1,000 miles on it. I still have all the parts that were taken off. Rotors, pads, calipers, etc. I'm thinking of selling them,
as they are just taking up space. Anyone out there looking for a nice, very near new set?
No. No R232 for me. Here in Newport Beach where I live, I have seen several running around already. Nice looking, but no longer the boulevard cruiser that I enjoy. A "removable" wind screen? Give me a break! And, I hate the "iPad" in my S580 and cannot even imagine one in direct sunlight. If and when I part with my "Mighty Mouse" SL, I won't be looking for another convertible.
Old Sep 24, 2022 | 09:07 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Almost immediately after I bought my SL a friend and I removed the newly installed OEM pads and installed a set of Carbon Ceramic pads. We did not replace the rotors or calipers. New rotors were installed as part of the CPO process by the selling dealer. The new pads perform as well as the OEM pads with 90% less dust. They are Powerstop brand and I think I bought them from AutoAnything for less than $100. No issues after about 10,000 miles.
Old Mar 5, 2023 | 08:03 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
CCB Cost?
I'm curious what it cost to change to CCB?
Old Mar 5, 2023 | 09:46 AM
Wolfman's Avatar
Super Moderator
The default price is well over $20k for the swap but a great deal will take it down to $16k or so.
Not for the faint of heart
Old Mar 5, 2023 | 10:17 AM
At the time, I was able to get it done for around $16K. Today, I know it would be over $20K. I did it because the CCB leave zero dust and I like the way they look.
Old Mar 5, 2023 | 10:31 AM
Below link is a great guide to the conversion (As noted * you won’t need some of the components shared with your SL65):
https://mbworld.org/forums/sl-class-...550-guide.html
Good Luck
