SL/R231: DVD stuck in cd changer
I am pretty sure it reads CD’s only. But I inserted a concert DVD, but it gives a looprunning error, or something like that translated.
anyway, the disc is not spinning and is just sitting there.
there is no eject button, only the option to eject all discs to be selected via the console controlls. It does indicate this one disc is in the changer, but it does nothing.
anyone have an idea how to get it out.
thank you,
jan
Try inserting another CD.
https://forum.autopumpkin.com/viewtopic.php?t=36
I tried to insert another CD but it touches the DVD not so deep inside. To no avail.
so I will ask the garage next service
If you feel brave or lucky
https://mbworld.org/forums/s-class-w...-magazine.html
You could unplug power to unit via fuse removal etc. Other than that you/or dealer may have to remove head unit and remove cd.
thank you,
jan
I thought disconnecting the battery has a rist of things not resetting properly. (In general, not directly for the soundsystem)
There is no button, the eject option cannot be selected in the menu.
Jan
Edit--When I looked in the SL this morning I snapped this pic. I am confused because I thought all R231 models had the same control unit. (the section with the volume control navi buttons, etc. under the head unit that I am pointing at? (name- control unit?). You are saying that you do not have this button directly beside the disc button in your car?? When I push the button pictured my disc ejects.
DVD movies can be played in the SL. Prior to CarPlay I watched DVDs all the time in the car while waiting on my wife to finish shopping. I still have a concert DVD in the SL now and that DVD is what I ejected as mentioned below.
Just in case, here is a video
That said, if the whole drive show as not available, try to reset the Comand
Maybe changed with facelift? But they function the same. If you have tried all that you feel comfortable doing maybe a stereo shop can help. Many Best Buys have car stereo installation or maybe a local reputable shop. Might be easier and cheaper than the dealer. Good Luck.
