SL/R231: Parklight in main lamp right side is out, any fix?
Old Apr 17, 2023 | 07:21 PM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
Originally Posted by hornethandler
Are you saying you have two of these light fixtures and that one of them is working?
If so, and if you are familiar with how to use a multimeter, you stand a good chance of finding the fault.
The fixture in this pic looks a little different than the one in your posts above... one of the LED mounting holes is broken.
If you look at the 8 orange pads in this pic, the top right one appears to be a “plated through hole” solder connection. However, the solder does not appear to be adhering to the sides of the hole and may be causing an open circuit.
If you take a closer look and are confident that’s the case, you could try reflowing that connection.
is same one, Jørgen just tryed get to whats under the black coat for measure , thats the damage you see.
Old Apr 18, 2023 | 11:14 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
While O.P's LED's may be functional. And LED's are typically pretty robust.
But for anyone who may need to undertake this repair in the future, even if on a different model MB.
There appears to be plenty of old stock of the OSRAM Dragon LED's in yellow and white available on eBay. (some in europe) Just have to determine the exact CRI/spec. you may need.
https://www.ebay.com/sch/i.html?_fro...OSRAM&_sacat=0
Old Apr 24, 2023 | 08:21 AM
Jørge Østvik Trondheim Norway fixed the case with a ford starter for the led light , and soldering in wires direct on the LED lamp , bypassed all electronic on the light card , just amazing .
Old Apr 24, 2023 | 08:24 AM
all fixed, before was fitted GTR grill , that upgradet car alot.
Old Apr 24, 2023 | 09:02 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
Just curious... how did you drop (reduce) the voltage from the connector to the 3 volts necessary to operate the LED?
Old Apr 24, 2023 | 10:20 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I like this grille.
Old Apr 24, 2023 | 05:51 PM
  #32
Somewhat unorthodox fix, but effective...
It will be interesting to see if moisture resistance and longevity are affected.
I would look for a cheap used headlight, even if broken, to salvage a functioning LED board if you come across one cheap.
Something like this below: (unfortunately this one probably has US yellow LED/lights)
Damaged R231 headlight $130
Good Luck!
Old Apr 24, 2023 | 06:54 PM
  #33
Good Luck!
I’m a little concerned about the lack of voltage regulation, as well as no current limiting resister in series with the LED. As the LED warms up it will draw more current and may eventually go into thermal runaway, smoking the LED, and perhaps even blowing a fuse.
Old Apr 25, 2023 | 09:04 AM
  #34
JettaRed's Avatar
Veteran: Army
Do you mean 3 volts?
Power is measured in Watts, but I get it.
Old Apr 25, 2023 | 09:08 AM
  #35
JettaRed's Avatar
Veteran: Army
Very cool. Is that the new hover model? Can't wait for it to come to the States.
Old Apr 26, 2023 | 01:00 PM
  #36
the reducer from the FORD ,that start the LED to light , the one you see on the left in picture.
Someone need take some action against mercedes ,one park lamp gone , and cant buy a 20 dollar part. is totaly wrong . Buy a hole lamp that nobody really need, guess is many others have same issue, or will have it sometime.
Old Apr 26, 2023 | 01:03 PM
  #37
the ford starter is the regulator, how it will work long term ,we dont know, the warning light inside also go away. So its test and see . hope for the best.
Old Apr 26, 2023 | 01:10 PM
  #38
Originally Posted by rmorin49
I like this grille.
yes, the grill really lifted the car alot , is also alot horsepower , is tuned ECU , and from dead stock , trotthle and turbo response is like another car, i have different AMG , but drive this one, i did not even bother push the trotthle was so slow on getting response . But after tuning, is like wow ,smoking rear tires in second gear at half trotthle. car is SL500, USA named 550 . Fuel use is also lowered around 0,9 liter per 10 km in speed 130 to 140 KMH
Old Apr 26, 2023 | 01:13 PM
  #39
I'm glad you came up with a fix. It will be interesting to see how it works out, and I'm looking forward to hearing more once you've run it for awhile.
Old Dec 27, 2024 | 05:34 AM
  #40
Dave130i's Avatar
LED PCB R231
park light taken out , is led . but where to order this one. had to drill hole in assembly to get to skrew to take it out .
Hello Tommyboy928,
Greetings from germany, i have the same problem. I found the manufacturer of the led pcb. I will attach the links here.
Can you tell me what steps did you do to get to the screw to take the pcb out? Did you remove the glas or will it be self explanatory?
Thank you in advance for your answer.
Best regards,
https://7-lights.de/Platine-PCB-pass...SAAEgIQ9_D_BwE
https://www.antparts.com/products/me...ule-2013-2015/
Old Dec 29, 2024 | 08:07 AM
  #41
Originally Posted by Dave130i
Hello Tommyboy928,
Best regards,
drill where marked in red
super ypu found the link to guys that have this, cost a fortune buy hole lamp, no remove glas.
Old Nov 12, 2025 | 11:20 AM
  #42
works fine so far , good we have link to German company that can deliver .
