SL/R231: Ship to Europe / Conversion?
Thanks!
Have you Googled "importing a US-spec car to Spain"?
Thanks,
Rick
Couple of things I can think of.
Fuel - use the 98 octane rating in Spain, 95 minimum
Turn lights have to be amber in Europe. You can try to keep your US ones but they likely require you to change them to the Euro version. Easy to do yourself and Ebay is your friend...
They may require you to have the speedo in km/h vs mph. You can't convert it without exchange but in case they check the car, set the secondary speed indicator in the instrument cluster screen (center) to km/h and make sure it shows at the time of inspection.
I believe Mercedes can code the Fahrenheit to Celsius if desired. Not required and there is no user setting.
Same for checking the tire pressure. Might be helpful to code it to KPA instead of PSI. This way it's easy to use the tire pressure gauges at the gas stations.
Good luck! The SL is the perfect car for Spain!
