SL/R231: Mystery odor - 2015 SL400
Old Nov 7, 2023 | 02:10 PM
Dave's MB's Avatar
2015 SL400
Friends;
For the last month, I've experienced a strange smell in the cabin that seems to come from the AC vents, whether the AC is running or not. My indy repair shop confirmed it is not R134. They also said no leaks or anything unusual could be found. No codes present, either. I replaced the cabin filter, but it didn't help. Can't detect the odor under the hood, only in the cabin.
I would describe it as a "chemical" smell, or maybe like a high end glue. Yes, it gives me another reason to drive with the top down, but I think something is wrong.
Since I don't really want to sniff glue whenever I'm driving, I'm wondering if any of you have any experience with this kind of thing?
Dave in Fort Myers, FL
Old Nov 7, 2023 | 02:34 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Check your trunk and see if any of the hydraulic lines are leaking. Might also want to check the pump under the trunk floor.
Old Nov 7, 2023 | 03:06 PM
Dave's MB's Avatar
2015 SL400
Thanks - good things to check.
Unfortunately, no evidence of leakage or a strong smell back there.
Dave
Old Nov 7, 2023 | 03:24 PM
rmorin49's Avatar
Veteran: Army
Then it's most likely something growing in your HVAC system. Mold can have a "chemical" smell. There are products available that can be used to kill the mold. Easy to do yourself.
Old Nov 7, 2023 | 08:49 PM
fscir60's Avatar
13SL550,11CL550,61 190SL, 67 300SE, 54 220
Odor
Mercedes makes a chemical spray for the evaporator. The evaporator gets wet from condensation and dirt sticks to it. Then doesn’t dry and mold grows. Try the spray and change the cabin filter
Old Nov 13, 2023 | 07:12 PM
visionatsea's Avatar
2013 SL550, 2011 Buick Enclave
I received notice for an extended warranty on the catalytic converter. Never had one go bad so don't know if a smell might be associated with it.
Old Nov 16, 2023 | 05:55 PM
DrivingInStyle's Avatar
SL550
My best guess is to get both AC filters replaced. Some strange stuff and smells roll out of those vents sometimes.
Old Nov 16, 2023 | 06:01 PM
JettaRed's Avatar
Veteran: Army
Originally Posted by Dave's MB
For the last month, I've experienced a strange smell in the cabin ...
Does it happen an hour or so after you go to Taco Bell?
Old Nov 21, 2023 | 11:29 AM
RonNSoCal's Avatar
2016 SL400 & 2021 C300
Good one!
Old Nov 21, 2023 | 11:30 AM
RonNSoCal's Avatar
Usually like rotten eggs
