SL/R231: Recognize this buildup?
Old Jan 5, 2024 | 08:29 AM
Xeno's Avatar
2013 SL63 AMG
Exclamation Recognize this buildup?
Mechanic says I have a coolant leak on my SL63. Does anyone recognize the buildup in this spot? Is it common?
Old Jan 5, 2024 | 11:11 AM
JettaRed's Avatar
Veteran: Army
Do you have blue or pink coolant?
Old Jan 5, 2024 | 12:09 PM
Xeno's Avatar
2013 SL63 AMG
I'm not sure. And the car is in the shop now so I can't check.
Old Jan 5, 2024 | 06:08 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Coolant leak ☹️
Mileage?
Old Jan 5, 2024 | 06:13 PM
Xeno's Avatar
2013 SL63 AMG
Originally Posted by crconsulting
Coolant leak ☹️
Mileage?
Just hit 40k when it happened.
Old Jan 5, 2024 | 06:16 PM
Wow, pretty low mileage for water pump issue. Do you know if the car sat for a while?
Could be a hose…
Old Jan 5, 2024 | 06:53 PM
Xeno's Avatar
2013 SL63 AMG
Could be a hose…
I'm praying it's a hose. I had a coolant level warning one time. I didn't even add any more and never had another warning, but my mechanic found the buildup in that photo above and wanted to do a pressure test, so that's what's happening right now. He described it as "it'll break, and then we'll order the parts to fix it". Kinda wish he hadn't told me. 😂
Old Jan 6, 2024 | 02:37 PM
cdk4219's Avatar
95 SL600
Probably time to go in there and replace all the plastic turbo coolant lines. They are problems and that’s what you’re issue is likely
Old Nov 17, 2025 | 07:28 AM
MDSL450's Avatar
2018 SL450 Designo
Follow up
Experiencing something similar in my 2018 SL450. Extremely slow coolant leak. Only about three cups of coolant lost over the course of 4 months. But nonetheless, I'm losing it somewhere.
Did the original poster ever have his situation rectified?
Old Nov 19, 2025 | 05:49 PM
Estes5's Avatar
SL550
I had a similar issue with a slow coolant leak. I'd occaisionally get a low coolant warning, but didn't see any obivoius leaks around the hoses. It looked like the top of the coolant tank was leaking. Had my indy run a pressue test and he found no leaks, which made no sense. Rather than start replacing a bunch of hoses, I replace the cap on the expansion tank. Ever since, no issues with coolant loss...knock on wood
