SL/R231: Tough stains from leather jacket
Old Feb 11, 2024 | 04:31 AM
Nasser_Almoumen's Avatar
2017 SL 500
Hello.
I have been trying to remove stains from the arm rest and the center console that seems to be from wearing leather jacket against the leather seats
tried leather cleaner , conditioner with no luck
any experiences with similar issue ?
Old Feb 11, 2024 | 08:56 AM
JettaRed's Avatar
Veteran: Army
Maybe ask someone at Joann Fabrics.
NOTE: Sorry, that's a fabrics store in the US. Have you searched YouTube? My interiors are black.
Old Feb 11, 2024 | 09:05 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Meguires red degreaser is amazing and can be used nearly full strength and will remove what you never thought possible. Dilute and try at your own risk for your leather. You need something strong enough to remove the outer dye only. Alcohol can work but is very harsh and 91 percent can be very damaging so I would not recommend it. You could also try leatherique which is a great system for cleaning leather, the best there is and can remove dye no problem if you follow the directions. Imo
Old Feb 11, 2024 | 09:07 AM
2017 SL 500
Yes, i searched youtube but its all about cleaning and removing general stains, not the ones specifically caused by leather jackets.
My interior is White
Old Feb 11, 2024 | 09:35 PM
JettaRed's Avatar
Veteran: Army
I've used this stuff called Pink Stuff in the past on tan leather and it worked great. Of course, the seats were dirty from use and not stained. However, it might work for you.
Old Feb 17, 2024 | 11:05 AM
JettaRed's Avatar
Veteran: Army
CORRECTION!!!
This is the stuff I used.
Amazon Amazon
Old Feb 17, 2024 | 12:02 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
What color is your interior?
You may have to re-dye the leather 🙁
Old Feb 17, 2024 | 01:10 PM
JettaRed's Avatar
Veteran: Army
He said it was white. 😳
Old Feb 17, 2024 | 03:28 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Be VERY careful using any harsh chemicals! I had the light beige interior in my ‘13 and had to have the driver seat re dyed after using a strong cleaning chemical. I now have Porcelain seats in my ‘16 and would probably only rely on one of the best professional detailers in the area if I had to do it again.
