SL/R231: Replacing A/C Condenser
Old Nov 4, 2024 | 02:19 PM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
While under my SL65 pulling the alternator I discovered a leak in the A/C condenser. This wasn't a total surprise. This past summer the A/C started blowing warm air, so I did a recharge and it fixed it. Of course, there's a leak somewhere so I also injected leak trace dye. What I see on the bottom of the radiator housing looks to be greenish dyed compressor oil. The good news, I suppose, is that I found the leak.
I consulted my trusty WIS for the procedures to remove/replace the A/C condenser. The problem is what they show doesn't seem to match up with what's on my car and so I doubt the procedure will work. Every video I've watched so far of people replacing a condenser they took off the front bumper.
I have an estimate of $3K+ from my friendly local MB dealer to replace it. Still waiting for estimates from a couple of local indy shops.
I'm half considering doing the job myself, but I don't trust WIS on this one. Does anyone know the actual procedure to use to replace the A/C condenser on an R231 SL?
Thanks.
Old Nov 5, 2024 | 09:28 AM
JettaRed's Avatar
Veteran: Army
I don't, but it can't be rocket science. If you need to remove the front end, I'm sure WIS has a procedure. For $3000, I would certainly try. ($3000 is an obscene amount. BOHICA!) A/C systems are pretty simple. Since your refrigerant has leaked out, there should be none to recover. That makes things a little simpler. You will need to have the system evaluated before replacing the refrigerant, and probably should replace the drier. You will want the system to be vacuum tested for leaks (which should be part of the recharging process). Search YouTube.
You could try to do everything yourself, but you will need to invest in the right tools (vacuum pump, pressure gauges). Depending on the other quotes you get, it may be worth letting them recharge your system.
Old Nov 6, 2024 | 06:38 AM
jmattioni's Avatar
I now have an estimate from a recommended local indie shop for $1,500. I'm familiar with most of the procedures but would have to buy the vacuum equipment. The condenser alone is probably $500. So I'm less certain about which way to go at this point.
I have the alternator on order and have to get that back in first. We'll see how that goes before making a decision.
Old Nov 6, 2024 | 07:57 AM
JettaRed's Avatar
Veteran: Army
Nissens is generally considered OE quality. Try www.rockauto.com.
Old Nov 6, 2024 | 01:31 PM
Bilbo7's Avatar
2015 SL63 AMG (R231)
Hi well my car The Lemon my 2015 SL63AMG has needed 2 condenser coils since 2020 one under warranty the other I had to pay for at an indy or here an approved STAR partner just over 2 years later so AMG will not contribute as its out of the 2 year warranty despite the fact its garaged from November until March since I owned it despite the coil has no stone damage and a huge patch of yellow dye on the face off the coil. Oddly one of AMG complaints reason for not paying is they made no err profit on the work....err but you sold the coil so no logic at complaints do STAR partners pay them for their registration I bet they do and a lot.
Here on the other side of the pond in the UK the Mercedes main dealer sourced coil was £660, the STAR garage labour £264 and the re-gas £90 making just over £1000 or $1300
I am a retired Building Services consultant with lots of experience in AC in large and small buildings but never worked on car but its all the same just different bits in different places that's still true in varying building designs and the old coil is so feather-light in weight far more than it needs to be and a common fault in coils is whats known as sand holes from tube construction.
If the coil had been hit by a stone, as taking it to a main dealership, agreed I would not contest Mercedes should at least make contribution as its at best a poor manufacturing fault!
Makes me wonder how often these coils fail regularly so what caused your failure a stone dent on the face of the coil??? If not why would it fail my car since I owned it sunny days only so its not corrosion from road salt etc
Old Nov 6, 2024 | 08:58 PM
RA1126's Avatar
Joe,
You can do this yourself. When I purchased my 2013 SL550 in Sept. 2014, the sales manager lied about curb rash on the bottom of the front bumper cover. They reimbursed me for the repair. So when I go the car home, (bought out of state) I pulled the front bumper off and had my friends at the MB dealer body shop do the repair. You will be amazed how fast you can have the front cover off the car. If you have it on jack stands and the front section of the wheelhouse liner off or loose and the bottom engine cover removed it's a 5 minute job. There will be one plug on the driver side, two 10mm (socket size) bolts visible in the grill and 2 or maybe 3 bolts on each side where the bumper cover attaches to the fender. Then you'll grab the top edge of the bumper cover with your finger tips between the headlamps and pull real quick and firm and she'll come undone. You'll see, really easy. When I prepared my bumper cover for the body shop it took me probably an additional 2 hours to undo the grills and lights and remove the Distronic sensors and parking sensors. My hands were worn out trying to unclip all the grill parts. You won't have to worry about that because you'll be going after the condenser. You can by a vacuum pump at harbor freight. Gauges are inexpensive there too. Keep us posted!
Thor
Old Nov 7, 2024 | 07:27 AM
jmattioni's Avatar
Originally Posted by THORGOD
Joe,
Thor
I'm considering doing the job. The bumper isn't really the issue. I'm more concerned with the procedure after that. I know the condenser is at the front but am not sure how to pull it. The WIS procedures are not at all clear.
I found issues with the WIS procedures to pull the alternator, which I now have out of the car and am awaiting a new replacement. For example, the procedure said to pull the alternator out in an upward direction. Well, that didn't work but it came right out the bottom of the car without risking damaging the cooling system radiator. The photos in WIS are also very misleading. In many cases they're showing you a photo of a car with components absent that were not removed as part of the procedure.
You bring up another topic of interest. I also have considerable scraping on the bumper underside. Pulling the bumper and bringing it to a shop for painting is an option I have considered. Most body shops I've consulted want to do a "collision" repair - get a new bumper and paint it and half the hood and fenders to blend the color. This approach is what I consider to be their inability to correctly match paint color. I won't do it. I guess it helps to have friends at the shop. I think I'll need to find a restoration or customization shop to do the job if I go that route. For now I've covered the bottom of the bumper with PlastiDip matte black paint, and it actually looks pretty good (photo attached). If I get the bumper paint repaired I would most likely re-coat the bottom part of the bumper with a peelable matte black paint.
What color is the car and how did the bumper paint job match up? Thanks.
Old Nov 7, 2024 | 07:31 AM
jmattioni's Avatar
There's no visible damage to the condenser that I can see with it in the car. It's definitely at the very bottom of the condenser because I don't see any sign of leaks in the fin area.
Old Nov 22, 2024 | 11:26 AM
jmattioni's Avatar
Just ordered the Nissens condenser from RockAuto. Thanks.
