SL/R231: R231 Vario Roof Diagnostic Aid
Old Jun 18, 2025 | 07:56 AM
steve sl550's Avatar
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
Does anyone have access to "R231 Vario Roof Diagnostic Aid" and if so can you pls post it.
I know there is one for the R230 but, it is different than the R231.
Hopefully there is a document for the R231 and someone can provide ...........Maybe Jetta Red who has helped with EPCs
THANKS, Steve
Old Jun 20, 2025 | 08:33 AM
JettaRed's Avatar
Veteran: Army
I don't have anything, but maybe @crconsulting does. In the mean time, I will check XENTRY.
Old Jun 20, 2025 | 08:56 AM
JettaRed's Avatar
Veteran: Army
Nothing in XENTRY, but the WIS has trunk lid adjustment instructions.
File Type: pdf
Old Jun 20, 2025 | 07:10 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Unfortunately, right now I don’t have access to anything other than the new version of the swine flu….
Old Jun 20, 2025 | 07:14 PM
JettaRed's Avatar
Veteran: Army
That sucks! Wishing you a speed recovery.
Old Jun 20, 2025 | 07:16 PM
JettaRed's Avatar
Veteran: Army
@steve sl550 did you have any DTCs? Seems to me some sensor should have started screaming.
Old Jun 20, 2025 | 09:02 PM
Interesting : there are no DTCs.
Only alarm is the "trunk open" dash indication if I don't push the trunk down and latch it.
Think I might have dodged a bullet and will be OK when I latch the trunk and perform a "roof open" operation and then a "roof down" operation should return the L arm to the correct position.
BUT to be safe I'm going to wait until I am at the Dealer next Tuesday.
AGAIN big THANKS for all the help (I was adrift without the videos) !
Steve
Old Jun 22, 2025 | 08:56 PM
Just for reference
Here’s most of the MB factory videos on the R231 I talked about in the PM. Roof Manual close procedure and other useful videos
https://www.youtube.com/@MBOwnersClub/search?query=r231
Old Jun 22, 2025 | 09:11 PM
This may help, from WIS : R231 open/close vario roof function
@steve sl550 see attachment below
File Type: pdf
Old Jun 22, 2025 | 09:20 PM
HI CR
Trust you are feeling better .
Many thanks for the "Factory videos"
AND the "function" PDF
Trust I will be OK and W/A Tues PM after I try to operate at the MB Dealer.
