SL/R231: Power Wind Blocker
Old Aug 17, 2025 | 12:45 PM
crank081's Avatar
2013 SL63 AMG, 2006 SLK350 Sold, 1998 SLK230 Sold
Power Wind Blocker
Is it possible to keep power wind block in up position with top down and ignition off?
2013 SL63
Thanks for any reply
Old Aug 17, 2025 | 07:13 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Don't think so. CRC will know.
Old Aug 18, 2025 | 03:41 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
2013 SL63
Yeah you can keep it in the up position with ignition off. see pic
You have to play games with the switch .
When you turn the ignition off, as it starts to lower, hit the switch to raise it. If you get it right, once the power cuts off and open the door, the screen will stay up.
Takes a couple times to get it right.
Good Luck
Old Aug 18, 2025 | 04:27 PM
crank081's Avatar
Thanks for the reply, I will try it!
