SL/R232: How much of "projection function" is enabled in US?
In the spec sheet of the SL I am looking at I see the the following list:42U Preinstallation for projection function for symbols
43U Preinstallation for projection function for animations
Can anybody help explain how does this work in US? I saw the video here:
Is it accurate?
Thank you!
https://www.youtube.com/watch?v=52rwB_a-cVg&t=160s
Is it accurate?
Thank you!
it’s build into the car but must be software enabled which it isn’t for the US.
Do a search on ILS to find options to enable it. Hopefully they can code it for you on the R232.
Expect this feature to be standard soon as the DOT finally updated their archaic regulations.
But this is standard fare for other models and commonly done for the W213 E Class and W222 S Class.
I understand it has been done for the W223 which would be the same generation as the R232.
Just a question if you want to be the first one. Check on the W223 forum or contact Benzninja, a vendor here for such services.
But there are places in Europe that do remote coding as well.
Good luck!
I also saw a note on a different thread that these options are controlled by the GPS location. So maybe it's just about removing that restriction when it's legal.
D9L Credit for missing standard 316 $-1,100
https://www.ipacket.info/W1KVK8AB1NF011940#MSRP
https://www.ipacket.info/W1KVK8AB9NF011894
Porsche sells the Matrix Design lights in the US but cripples the functionality. I had read that even after the DOT was ready to legalize the functionality, Porsche would not unlock it for those that had actually paid for it.
Thanks!
I finally found a picture of an SL with the missing digitla lights at Park Place Dallas MB, and compared it to the cars with the digital lights. There's no difference in headlight design. They look the same.
