SL/R232: All Season Tires
2021 S450 4Matic
Putting the drive dynamics, people/goods hauling...etc aside, one often heard pro-SUV argument is that ''with SUVs' taller height, the driver has better visibility and surrounding awareness, thus it is safer. And similarly, the taller height gives an advantage in an accident with sedans or wagons''.
What do you guys think? Do you buy this or not?
Super Moderator
Received 3,181 Likes
You still have the GLE wolf? I thought you got rid of it due to low milage? I will say, while SUV’s are definitely not my cup of tea, the GLE is a nice compliment to a GT and M8. I do miss seeing Emerald Green in my driveway.
I do find having one SUV in the garage is nice for the occasional Ikea or Home Depot runs, as well as the dogs, but a wagon would definitely do the job all while looking and driving better. Sadly only the A4 Allroad is available in the compact class and I was unable to convince the wife of it over the GV70. Thankfully the wife doesn’t mind SUV’s at least so I can stay low to the ground.
'22 AMG SL55;'23 Porsche Cayenne S Coupe;'13 Porsche Boxster S
We had leased the GLE and it was too cheap to keep it, given the low mileage. I think it was 7600 miles or so in three years which feels low for a utilitarian truck. Re. station wagons, I tried to talk my wife into trying one (even the E63s or RS6) but that was a hard no unless I would be the only one driving it
Wolfman (04-20-2023)
drgek (04-20-2023)
Super Moderator
When comparing with sedans, coupes, roadsters and wagons, SUVs do sit taller.
As for SUV's being safer, there is data supporting multiple points of view. Bigger, heavier vehicles have the upper hand, but also those with low center of gravity. I do believe that you can avoid accidents much better with a lower car than a taller one and good vehicles safety systems are essential for avoidance and survival.
That's why we drive German cars
Drone_S213 (04-20-2023)
#32
your entire premise makes even less sense when you have another car. There is no reason not to run summers if that's the case. The only merit for all seasons is if this is your dedicated daily. (Which is rare for owners of a car like this in the first place but does happen.)
#33
I don't think so. Spring/fall has plenty of days/evenings in the 40-50F range no matter where you are in the country, wet or dry...maybe even top down. And in the southern half of the country all the way through winter. And I do not think it is "rare" for these to be driven daily.
anyways, plenty of data here for people to make their own mind up.
#35
I suspect his great results are:
- no need for two sets of rims and tires
- can drive the cars c43 and e53 in the snow without changing wheel sets
- the way he drives doesn't push the cars to the limits to apparently necessitate all summers or all winters in his opinion
- all seasons lasted longer than winter or summer tires
- this was a less expensive route than carrying two sets of wheels/tires and storage and paying to swap them seasonally
Yes, exactly!
#36
Received 2,268 Likes
PFL205.064 with M276.823
The 'all-seasons are good for no seasons' line is antiquated. High-performance all-seasons are extremely capable.
Summer tires are a poor choice for most people, and are arguably the "inferior" tire for the way almost everybody uses thier cars. Softer tread compound and stiffer sidewalls result in much faster tire wear and stiffer ride, and grip is severely compromised if below 50F or wet. Generally noiser, too. 99% of drivers do not push their cars anywhere near the limits that a high-performance all-season provide, let alone a dedicated summer tire (nor should they on public roads).
Dedicated snow tires are great for snow, but terrible in dry and worse than all-seasons in wet.
Summer tires do provide great test numbers on a dry track for car magazines, which is why they are fitted by Mercedes-AMG.
#38
It depends on tires. UHP tires in all categories incl winters are performing better than others in wet conditions. I summarized the stopping distances in feet per mph from tirerack tests (though different temps might change the results btw different days and also different tire sizes has some impact) using the same car tests:
Michelin Alpin 5 UHP winters are closer to A/S UHP tires in wet, and beats Michelin summer and other A/S tires in stopping distance which is more important to me than lap speeds. Alpin 5 saved me from an accident last year when a van pulled in front of me instead of waiting on the non-moving exit lane on a rainy day...
Per Federal Hwy: "Most weather-related crashes occur on wet pavement and during rainfall. Each year, 75 percent of weather-related vehicle crashes occur on wet pavement and 47 percent happen during rainfall."
https://ops.fhwa.dot.gov/weather/wea...ent%20annually.
#41
