SL/R232: Limp mode?
I did get caught in a little bit of rain today, but I would be surprised if that damaged anything. The problem seemed to resolve itself after I parked it for a few hours. But the problem started happening again on my ride home. Any ideas? Is this something that I can fix on my own? Will it resolve itself overnight maybe? I really don't want to have to bring it in to the dealership. The last time something happened to my other car, it took a month to get a service appointment.
would this work?
FOXWELL NT510Elite fit for Mercedes Benz Diagnostic Tool,2023 Newest Full System fit for Mercedes Scanner Bidirectional Scan Tool,OBD2 Scanner Car Code Reader ABS Bleed SAS Oil Light Reset CKP Relearn https://a.co/d/dUgxN6O
https://www.mycarly.com/
engine, oil, transmission temp didn’t seem out of ordinary, but did not take notes.
. Yeah that's not really hard driving for an AMG, so must be some kind of a malfunction. You probably will have to take it in and get it sorted. These are complex machines plus first model year troubles.
My advice to you don't go to the dealership unless you're armed with photos of cluster messages and diagnostic codes you obtained from your ODB scanner. So have the OBD scanner in the car at all times, and when the problem shows its ugly head hook it up and pull the codes immediately. Then and only then take it to the dealer. Also keep in mind that if you get a CEL (check engine light), if it is flashing you need to stop the car as soon as possible at the nearest safe spot and take it immediately to the dealership. Don't drive it. If it's a constant CEL, you can drive the car to the dealership but don't push it too hard as the engine is not well and pushing it may cause the issue to develop into a major failure.
One time I was driving at around 30mph and the car felt sluggish. A couple seconds later a flashing CEL came on. I stopped on the shoulder and turned off the car. A couple minutes later, turned it back on and the CEL was gone and the car drove and shifted normally. Took it to the dealership and they scanned it for codes, and you guessed it: there was nothing stored. A few weeks later, the problem came back. I took it to an indy who found out one of the coils was failing. I changed all the coils & spark plugs and the problem never returned.
So in your case, the problem is likely to come back again. Just have the reader handy. If you don't get a flashing CEL, keep the car running and scan it for codes. Once you get the codes and photos of any messages on the cluster, take it to the dealer so they know where to look and they feel less compelled to dismiss the issue. Also remember that turning the engine off then on will in many cases resolve the issue temporarily until it comes back again which almost certainly will.
