SL-Class (R232) Discussion on the 2022 R232
SL/R232: Winter tires...
Old Sep 23, 2023 | 09:44 AM
silviang's Avatar
2022 SL63 AMG
Winter tires...
Hello,
I wanted to know if anyone has found a good solution for winter tires for SL63. I am thinking to go all the way to 19 - and get both wheels and rims. But I cannot find reasonable prices...
Cheers!
Old Sep 23, 2023 | 08:42 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
You can check tirerack or https://www.mbusatirecenter.com/ for options.
I don't know where you live and what you are looking for, eg dry/wet performance with snow performance vs heavy winter snow/ice performance. I drive Michelin Alpin 5 UHP and are good for light winters. Vredestein Wintrac Pro are reasonably priced and good for dry/wet climates. In my case Alpin's were the only ones in stock 2 years ago. Here are good reviews of winter tires:
https://www.tyrereviews.com/Article/...-Tyre-Test.htm
https://www.tyrereviews.com/Tyre-Tes...-Tyre-Test.htm
2021 comparison with Michelin Alpin 5: https://www.tyrereviews.com/Article/...-Tyre-Test.htm
https://www.tire-reviews.com/Article...-Tyre-Test.htm
Old Oct 10, 2023 | 07:45 PM
kcirm's Avatar
2022 SL 63
Hey fellow winter man.
I'm going with some used 20inch winter tires from a friend the had a gt63. Tires are quite easy to get, the problem are the mags.
If you stick to spec, there are no mags available on the market for this car. I went to a reputable mag shop and they ran a 3rd scan on the brake assembly to know how much clearance I actually need. They'll come back to me with results. Hopefully, I'll be able to pick up some mags off the shelf for winter I will update hre
Old Oct 14, 2023 | 03:43 PM
silviang's Avatar
2022 SL63 AMG
Hi,
In case others are interested I got these tires from TireRack - quite expensive but it is what it is...
Old Oct 27, 2023 | 12:55 AM
James Nevin's Avatar
2022 SL63,2021 GLS63s,2021 GLA45
I have a set of snows
Originally Posted by silviang
Hi,
I have a set of 21" staggered OEM sized Pirelli snows as shown . I used for 2 mos on my 22 SL63 -have traded car-If you are near Toronto KW area message me--$1200-no tax
I have a set as above I used for 3 mos on my 22 SL63-If you are in the Toronto or KW area they are available for $1200 Canadian-no HST or luxury tax" nevinjp@yahoo.com"
Car has been traded
Old Nov 13, 2023 | 12:42 PM
kcirm's Avatar
2022 SL 63
As promised here's a follow up on the 3D scan I got down.
I always downsize for winter so this is the fitment I'm getting installed on Thursday
4x 20inch BR14's mags
2x 3mm spacers for the rear
2x 265/40/20 Michelin Pilot Aplin 5
2x 295/35/20 Michelin Pilot Aplin 5
