SL/R232: 2022 W232 Grinding Noise Hard Left/Right Turn When Cold
What could be the cause of that?
is sound occurring at end of wheel movement or the entire time?
I would get on lift and move wheels left and right to check for interference where something is touching but should not be.
If OK. I would check wheel bearings and brakes.
Then check steering rack
Then steering linkage external to cabin
then Steering wheel and linkages etc inside.
I also read these have rear wheel steering. Wonder if it could be due to that system?
I think I will bring it in. I have almost 600 miles on mine and I’m planning to take it to the track once I cross nicely over 1000, so I need to get it sorted.
Wikipedia on Ackermann
From the article "The use of such geometry helps reduce tire temperatures during high-speed cornering but compromises performance in low-speed maneuvers" This is common on high performance cars with more aggressive steering geometry, wide tires, and summer rubber compounds in cold weather. The tread doesn't "slip" cleanly over the ground near/at full steering lock when moving due to the different tracks each front wheel takes, and you end up with juddering and noises as the slip occurs.
I have 22SL63 150 Miles just purchased, I noticed the same thing when making the sharp left pulling out of my driveway, happens every time, I thing you are on to something with your explanation
After cold starting, and trying to turn steering wheel not even a full turn, there is a tire plowing on pavement sound, with accompanying ratcheting thumping.
Dealer said it’s normal until tires warmup.
