SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuel pressure regulator/dampener
Old Nov 18, 2020 | 03:52 PM
J911brick's Avatar
W211 W204
I've been searching but cant find anything on how to test the fuel pressure regulator/dampener. Does anybody have any insight on this? How does one know if it needs to be replaced?
Old Nov 23, 2020 | 08:55 AM
AlterSchinken's Avatar
1985 380SL
Is your car D-Jet or K-Jet?
Old Nov 23, 2020 | 09:04 AM
J911brick's Avatar
W211 W204
k-jet
Old Nov 24, 2020 | 08:52 PM
J911brick's Avatar
W211 W204
Really- nobody?
Old Nov 25, 2020 | 10:57 AM
silvermoon1959's Avatar
2014 E350, 1989 560sl, prior 2001 E320, 2008 E300
This might help.
Old Nov 25, 2020 | 07:28 PM
J911brick's Avatar
W211 W204
Originally Posted by silvermoon1959
Thanks for your contribution, however the fuel pressure regulator/dampener is different from the fuel accumulator.
Old Nov 26, 2020 | 06:43 AM
Regulator not dampener
Yes, Sorry, I realized that as soon as I posted then wasn’t sure how to delete my post.
This guy has a couple of good videos on checking the regulator etc.
https://www.youtube.com/playlist?lis...are&playnext=1
good luck.
Old Nov 30, 2020 | 02:12 PM
1985 380SL
The pressure regulator valve controls the main system pressure, which should be 5 to 5.6 bar. If this is out of spec high or low the pressure regulating valve has a problem. The pressure can be adjusted slightly by changing some shims in the valve. What year and engine do you have?
