SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuel Accumulator
Old Sep 27, 2024 | 11:55 AM
frostsdad's Avatar
2024 GLS450W4, 2016 S550 4MATIC (W222), 1972 350SL (R107), 2012 GLK350 (X204)
Fuel Accumulator
Replacing fuel lines in my 1972 350SL. Wanted to replace the accumulator. The one that arrived has an “extra” port. Pic below. Can I “tie off” the port I don’t need? I thought what I was ordering didn’t have the extra port, but the one that arrived was what I saw in other pictures as well. Last but not least, if it can’t be tied off, is there risk using the old one? I assume it has worked fine but we replaced lines, the fuel filter, etc because it has been sitting for about 5 years. Thanks in advance.
Old Sep 28, 2024 | 05:24 PM
frostsdad's Avatar
Disregard - used the old one which works fine and returning the new part!
Old Sep 30, 2024 | 09:35 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Well, for what it’s worth, you don’t need to connect the leak line.
That is with the small nipple on the fuel intake swirl cage is for.
I just cap off the leak line on either end and put a jubilee clip over.
