SL55/63/65/R230 AMG: Warning: SpeedtuningUSA Damages ECU
My friend's SL55 ECU was sent to Speedtuningusa for a software upgrade. The ECU came back and since then, the SL55 would just shut down for no apparent reason, even while cruising at highway speeds on the freeway. The car had 1,430 miles.
Because of safety issues, the car was towed to the dealership where it was determined that the problem was within the ECU, and that a new ECU had to be ordered from Germany - OUT OF WARRANTY.
It was discovered by the dealer that the ECU was physically tampered, and the mainboard was cracked.
Now and $2,830 later out-of-pocket for the new ECU and diagnosis/repairs, the car runs perfectly fine however, now WITHOUT WARRANTY... and, Speedtuningusa denies the $2,830 claim or does not even offer a refund for the upgrade.
Just a heads up for those considering Speedtuningusa software.
It's my greatest fear when considering mods... as well it should be.
~ Ian
work.
Sounds more like you need to find a new dealer. I have had my dealer send my ECU directly to Kleemann to get some program defaults coded out (dealer does not have the ability but Kleemann does) to resolve a "check engine" with the secondary O2 sensors and they also shipped my difff to them for the LSD install and then installed it back into my car. Oh, and they also installed my IC mod and inspected my K2 after 300 miles to make sure nothing was loose or needed to be torqued again (headers & pulley).
In a month or so they will be installing my new throttle body off the V12 Bi-Turbo (they meaning dealer) when they change out my SC under warranty because the chirp issue has been fixed with the newer SC's.
The moral of this story is that you have a simple ECU and they are acting that way.
Please find a new dealership that will treat you right.
Jason
So true my friend.
Please please guys, remember, you get what you pay for. When Kleemann did my ECU, they grounded themselves and the unit before working on it and did everything but wear a surgical mask and gloves. They were meticulous. Oliver, God bless him, works in a beat up trailer in the back of a dealership I believe.
EVO/Klee/Renn....you pay the cash, with no backlash.
Don't mean this at all as smart a$$, but with the cash for an SL55, why not spend the extra 1500$ to have it done by the big guys....that seemed odd.
~ Ian
Speedtuning doesn't take the ECU apart. All they do is 'flash'the ECU with the new data. I doubt if they did anything to your friend's ECU....it sounds like the problem was on his end. But everyone else is right.............Find a new dealer!
There is no way to damage the ECU by simply removing it from the vehicle, nor is it possible to have all the torx screws tampered by just pulling the ECU out.
Bottom line, someone opened the ECU and it was not on this side.
Just to set things straight, some or if not all ECUs are opened when they are bench-programmed (as in Speedtuning's case). The only time they are not opened or touched is when they are in the car and programming is via the OBD2 port.
I have just spoken with Oliver @ Speedtuning. He is stating that he has NEVER received a complaint about a failing ECU, or one that has been tampered with. If your friend is real (which I am begining to doubt)...have him PM me with his phone number and I will do a 3 way call with Oliver and get to the bottom of this. I have no interest in this except to help a friend from being falsely accused and to help your friend get his car going.
In all my dealings with Oliver and Speedtuning, they have been nothing but forthright and upfront...and the work has been of high quality. I don't believe with an ECU flash that the unit has to be taken apart in any way. Therefore, this can only be the fault of the person who removed and played with the unit (if it happened at all).
So, if your friend is really having an issue with this ECU, have him get hold of me and I will help. If not, this BS needs to stop as you are slandering a fine business and an honorable person.
find out if the ecu has been tampered with. Also if you don't tell your
insurance company and kill someone in an accident you won't be covered
....Seems like it was BS
