SL55/63/65/R230 AMG: Air Injector Failure, Implications
Car is now at the dealer, we'll see what happens.
I am stunned by all this. I find that a design that could make a vehicle unsafe to drive (or tow without damage) due to an air pump failure (or software controlling the air pump) seems just a little on the delicate, not very well thought out side.
Anyone else have experience with anything like this? I want to make sure this NEVER happens in the future. I also want to understand if there are any more "gotchas" like this one of which I'm unaware.
This is a 2003 SL55. I’ve had lots of creak and rattle issues (all resolved) but never a mechanical failure, till now.
Comments?
However, they are still not sure what motor or pump was running with ignition off for over 40 minutes. In the right front of the car, near the SBC box, what pump or fan comes off and on every few minutes? What could keep running with a sound like a small shop vac for so long? No error codes are posted in the diagnostic memory.
BTW, when you say the motor 'burnt out' you don't mean something like this right? https://mbworld.org/forums/sl55-amg-sl63-amg-sl65-amg-r230/123578-sl55-spontaneous-combustion.html
The sound isn't a groan. Can't tell exactly where it is coming from. The sound is very similar to a vacumn cleaner. It comes from around the SBC box area, but I can't tell exactly where. When it failed, when it kept running, it was actually louder than a vacumn cleaner, sounded like a large shop vac.
BTW, when you say the motor 'burnt out' you don't mean something like this right? https://mbworld.org/forums/showthread.php?t=123578
The problem was an air injector pump used for emissions. A relay became stuck (no error code) and the motor burnt itself out. All fixed now.
Still can't believe the nonsense I got from Benz support on the phone.
Live and learn.
