SL55/63/65/R230 AMG: Spontaineous Rollbar Deployment
Old Mar 26, 2006 | 06:56 PM
IanSL55's Avatar
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
20 minutes ago I'm rolling down the hill from my house with the top UP and WHAM! My rollbar partially deploys. So I stop the car and try to lower it via the center console and get a "RAISE ROLL BAR" warning in the status screen. I try to lower the top but get nothing. So now my roll bar is wedged up about 85%... won't raise fully... won't lower... top won't go down...
I'm going to the dealership tomorrow but curious if this has happened to anyone before.
~ Ian
Old Mar 26, 2006 | 07:06 PM
CASL55's Avatar
2004 SL55, 2005 E500 Wagon
That's a royal pain. You have my sympathy. I've never heard of anything like that, but lots of automation means lots of things to go wrong. When you find out what went wrong, plese let us all know.
I'm curious: in normal operation, will the rollbar deploy when the top is up?
Jim
Old Mar 27, 2006 | 04:33 AM
IanSL55's Avatar
Thanks Jim, I'll post what I find out...
~ Ian
Old Mar 27, 2006 | 07:53 AM
sprins's Avatar
G55, SLS, smart eq
In this video you can also see the rollbar deploy when the SL55 is taken over the track. But abviously this happens because of the rough handling of the car over the track. Just cruising and then deploying the rollbar seems like an electronic malfunction of some sensor or what have you. Can be fixed easiliy probably but still a pain.
Old Mar 27, 2006 | 08:05 AM
Scruffyone's Avatar
SL55, ML500, GT3 RS, 997C2S
Jim
Yes it will. Happened at the 05 AMG Challenge to guest celeb driver Tommy Kendall when he crested the uphill run at Lime Rock. He was in a SL65 and he thought his passenger did something.
Old Mar 28, 2006 | 02:49 PM
AAG's Avatar
AAG
SL55 AMG
Good video... man, she has a dirty laugh.
Old Mar 28, 2006 | 03:52 PM
sprins's Avatar
G55, SLS, smart eq
Yeah, she gets al excited over the SL55
Old Mar 28, 2006 | 06:49 PM
IanSL55's Avatar
OK, here's what to do to fix it...
When the rollbar deploys with the top up it doesn't lock in place - it';s basically in rollbar limbo. You need to RAISE it using the controls on the center console until you hear the locking noise. It will then lower normally.
~ Ian
Old Mar 28, 2006 | 10:36 PM
qualcomm65's Avatar
sl65
my roll bar deployed and had to go to benz to lower it , it was stuck also. it has happened several times. i had several probs and they found a hydrolic leak in the roll bar motor
