SL55/63/65/R230 AMG: Questions from a new SL55 AMG Owner
Hello everybody,
Before I begin, I'd like to thank you for all your help. I just bought a '03 SL55 AMG and I have several questions to ask.
1. Is there anyway to remove the speed limiter from the car and if so where do I go get it done and how much do you think it will cost?
2. I was inserting a CD into the in-dash CD drive, it got jammed and it is stuck in there. What is the best way to remove the CD and if need be where can I take it to get it removed.
3. I have a bluetooth enabled cell phone and I was wondering if it is possible to install some kind of bluetooth cell phone car kit so that the pre-installed car phone kit can be used with my cell phone via bluetooth?
4. I was thinking about installing an ipod adapter so that I can use my ipod in the car. What is the best ipod car adapter out there for an sl55? I have the neo ion installed in my civic and it works great except for controlling the ipod. I was wondering if there was another product that has better car integration with an ipod.
5. As far as maintenance is concerned, how much does it cost to get your brakes replaced, mb certified tune up, etc.
6. I was thinking about getting the SLR type turbine-shaped wheels for the car. Does anyone here know if MB sells those wheels or if you need to go to a custom wheels retailer to purchase those?
7. What is the fastest way to drive the car off the line, e.g. should you use manual to drive, or just use S. I know that W is only to be used for winter.
Thank you for all your help. Thanks again!
1) There's no easy way to remove the speed limit. AMG offers a module to remove the speed limit, but I don't know whether it's available separately. Ask your local MB dealer about pricing.
6) The turbine styled wheels are available from Lorinser. They're not available through MB. I just ordered these wheels for my SL55. I'll also do some other minor modifications (like the grille in car's color) etc. Will have pics early next week.
1. I don't think the AMG module is availble in US, you will need to send ur ECU to tuner like Kleemann, Renntech or some1 else has also mentioned about sending your ecu to powerchip to just remove the limiter if you don't wnat to upgrade other parts of the car but if you are flashing your ECU, you might want to consider getting headers and pulley etc. you wont' regret it.
3. www.wireless4mb.com
7. I would just leave ESP on and in S because there is a slight lag between pressing the button and when it shift. I would just ease on the throttle at first and when the tire grips. Just floor it.
'09 911 C4S
4. Not sure if you car is compatible, but MB has its own ipod kit. Call your dealer's parts department and give them your car's VIN and they can tell you for sure.
6. Those are the same as Lorinser RS-8 Wheels, looks cool, but weighs a ton.
Thanks!
Thank you all again for your input and suggestions. Those were the wheels that I was looking for. The best price I found was around 3700 dollars without any wheels, just the chrome rims. Thank you!
2004 CL55 AMG
Originally Posted by philpre
Hello everybody,
