SL55/63/65/R230 AMG: SL65 exhaust: Need advice
I have an SL600 but don't like the soft exhaust and really want a quad tips look. I was thinking about the Eisenmenn exhaust but >$3000.00 seems a little steep to me. I got a quote from Renntech for about half this price to install SL65 mufflers on my car and modify the rear bumper so they will fit.
I would appreciate if anyone with an SL65 would tell me what you think of the exhaust sound. I really wanted the quad exhaust look and I can probably just change out my tips for very little money but if the exhaust sound will increase due to the new mufflers then I'm willing to spend the money. Any input would be appreciated. Thanks.
You may want to ask Renntech what the difference is, although they are a competitor of Eisenmann and you may not get a neutral answer. Remember, the Eisenmann is also supposed to give a pretty good HP/Torque increase....I am not sure if the SL55/65 would give any.
I think the mufflers are for sound and emissions. Emissions are not checked in Florida where I am living.
Removing the mufflers in a car with twin turbos and the cats in place should not make the car obnoxiously loud. I'm considering trying this out on my CL65, though it is already louder than an SL600 at idle.
Anyway, thank you both (DoctorV8 & WoodHeBe) for the advice. I think I may try the straight pipe option or replace the mufflers with a good high flow aftermarket set (magnaflow, Borla, etc...) at the recommendation of a custom muffler shop. I'll post my results whatever I do.
I am probably going to be right behind you in doing the same thing. It may be a bit louder on a CL65 vs a 600 car....
WoodHeBe,
Did you remove the mufflers and resonators all at once on the S600? Or did you try just 2 first? Thanks for sharing your experiences.
The massive low end torque of the Mercedes turbocharged V12s falls off above 4500 rpm...while there are probably many factors involved in this, including sizing of the turbos and tuning to minimize the risk of transmission damage, I wonder how much of a factor the restrictive exhaust system is.
I called Renntech and they quoted me $1500 to do the job. Talk about overpriced!!!! I actually couldn't believe it but I kept calm and said thank you but no thank you. Unfortunately they probably would do a good job, but come on $1500 for straight pipes!
I'll be interested in hearing the RennTech exhaust when it becomes available...and while she's on the rack, I'll probably get the toe links replaced too...
How would you like to meet some day so we can run the cars side by side and see if a well broken in SL600 Renntech is faster. I'm curious plus I just love to street race when possible (in a safe place obviously).
So I cut off the stock tips, mufflers and resonators. I then ran a nice 3 inch mandral set of pipes from where the resonators were all the way to the back and reinstalled the factory tips and hangers. Total time 1.5 hours labor, very simple and clean. I would guess any other shop would charge about $200-$250 for this.
The best part is the sound. It has a quiet idle with a nice rumble, barely audible inside the car but then when you step on it you get a perfect deep throaty note. Not to loud not to quiet, just right. It will growl at you if u stab the throttle. I have never heard another car with this note either. Its different but really nice. Sounds alittle like an inboard Cigeratte boat from 100 yards out maybe, almost like a tone under water, I am hooked on it now! No resonance in the cabin either. When cruising at 70 or higher you can barely hear the note, its there but you have to listen.
So you get the best of both worlds, loud when you want it and quiet when on the highway. Perfect!
I appreciate your advice and I would love to make my car sound as you described. I also would like to get a set of dual tips for each side but the problem is the bumper angles. Unless I can get angled tips, one of the two will look like is sticks out and not be flush with the bumper. Anyone out there know of a set of tips that will work?
