SL55/63/65/R230 AMG: kleeman lsd question
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
will a used 04 E55 kleeman lsd with cut gears fit into my 03 SL55 without problems. I thought the ratios were different? 2.65 for E55 and 2.82 for SL55? thanks
Former Vendor of MBWorld
Call Satish or Billy or Sunman at 248-668 6793 (Motorwerks). They are reps for Kleemann and did the LSD on my SL55. They've done many more also.
i would suggest a ecu upgrade, asp pulley upgrade and even the 80mm throttle body upgrade, by vrus on e55 forum, instead of lsd first.
ASP pulley produces more boost than Kleemann or Renntech pulley and is much cheaper. However, I would still reccomend Kleemann or Renntech simply because they spend way more money on R&D (and a lot more cars use their products without problems) and you can be sure you're getting a quality product. You should get pulley/ecu + headers, and then get an LSD.
05 SL 55 AMG, 01 Turbusa/8.43 @ 183..1/4 mi.
Kleemann and Renntech pulleys increase the boost by around 2-2.5psi, while ASP increases the boost by around 3.5psi. In my opinion, 1 psi more equals around 10-20whp more. You should do a search on the E55 forum, a lot threads about different pulleys and ecu's.
