SL55/63/65/R230 AMG: How Many Bent Your 20's
Old Mar 12, 2007 | 02:03 PM
RoydRage's Avatar
SL55
Question How Many Bent Your 20's
I'm going to post on the original thread on what wheels you've all helped me decide on...
THANK YOU VERY MUCH!
Now I have to decide between the 19" and 20" version.
A Quick Poll:
How many of you bent your 20" rims?
AND;
How much worse is the ride? Slight, considerable, Bearable - unbearble, Worth it - Not worth it? Would you do it again, or go 19" if you had it to do again?
Thanks!
RoydRage
Old Mar 12, 2007 | 02:17 PM
sporters78's Avatar
2003 porsche 996tt Ruf, 2005 SL55 Renntech
beenable 20" rentech but well worth it for the looks and ride just fine
Old Mar 12, 2007 | 02:48 PM
joec1101's Avatar
'09 E93 335i
Both my 20" Lorinser LM5 right side wheels (20x11 & 20x9) bent after about 8K miles even with careful driving. Having said that, the Lorinsers, just like most other "tuner" wheels, are cast aluminum and weak.
I currently have some 20" forged 6160 T6 aluminum 2-piece wheels being made that are 10" wide instead of 11" in the rear which will allow for a slightly taller sidewall to help prevent damage. That, combined with the strength of the forged wheel, should help out tremendously with bending issues.
I highly recommend you go with a good forged wheel instead of a cast, especially if you are going with 20".
As far as ride quality, there's definitely a noticeable difference. It's a harder ride and you will feel more bumps in the road. But I would do it again because it adds so much to the look of the car.
I will post after I have my new wheels & tires to let you know if the ride is any better with the slightly taller sidewalls. My new tires are also a different brand, so that may make a difference as well.
Old Mar 12, 2007 | 03:35 PM
seattlecarfreak's Avatar
all my 20" rims always get bent living in the city.. one pothole and 2 rims get bent in a matter of seconds.. that's why i buy cheap rims and replace them every year.. i have 18s on my porsche and no problems though
A Quick Poll:
AND;
Thanks!
RoydRage
Old Mar 12, 2007 | 05:13 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
I have Carlssens' 20'' and the ride is fine on E-way and smooth roads. Ride is definately harsher with 20's but not bad enough to not make the switch. Slight bumps like business entrances from main drag is where I notice it most. I put the 18's back on in the late fall till spring even though I don't drive car in snow or salt conditions. I bent 2 of the rims a little with careful driving but they were repaired perfectly.
Old Mar 12, 2007 | 07:14 PM
mark anderson's Avatar
2019 S63,2015 SL63, 2007 SL55, 2006 SL55, 2003 SL55
I just took off my 20" wheels and went back to 19's. I prefer the look of the 20 but I think the ride is much better with the 19's.
Old Mar 17, 2007 | 09:15 PM
jeffster's Avatar
I have a set of 20” lorinser’s lm5’s. If they bend can you straiten them? And if you do straiten them how much weaker will the wheel be?
Old Mar 18, 2007 | 09:33 AM
Mrdredd's Avatar
i have 20" Asanti's and they haven't bent after about ~14K miles... and the ride isn't much differant... if I remember correctly, w/ 19" the car feel's more loose and the tires break loose all the time.
Old Mar 18, 2007 | 12:24 PM
joec1101's Avatar
'09 E93 335i
And according to Asanti's web site, their wheels are forged. I think this makes a big difference. That's why I'm going with forged this time around. The Lorinsers are just too weak and soft and bend too easy.
Old Mar 18, 2007 | 08:33 PM
Mrdredd's Avatar
I wasn't disagreeing with your statement, just adding more information into the topic
Old Mar 20, 2007 | 05:04 PM
Keng1's Avatar
2008 M6 Vert
20" Brabus here. So far so good.
Old Mar 21, 2007 | 03:57 PM
cappuccino's Avatar
SL-55PP
go for the 20s
Mine are 20" HRE 540R with CSC3 tires. I have installed them for 6 months and I think the ride is more confortable than my previous one which were 19" AMG wheels with bridgestone tires(RE050)....and the look, of course is much much aggressive~~~
Old Mar 21, 2007 | 10:20 PM
RoydRage's Avatar
SL55
Thumbs up
Cappy,
Wow... What you said right there is real important... Cause I was thinking of Bridg's with the SL65 wheels... I hear the PS2's are the bomb... where ride, and other things are concerned... I'm leaning this way.
Thanks,
RoydRage
