SL55/63/65/R230 AMG: 55/65 tire pressure on 19" wheels
I am curious what you consider your ideal tire pressure on AMG 19" stock wheels, in terms of traction and comfort. I am particularly interested in the in SL65.
I find that MB's listed cold tire pressure numbers on their sticker simply too low.
Thanks,
Wolfman
Nobody on this board having an opinion of what you found to be the best tire pressure? Is everybody just going with the MB suugested settings?
Please post some replies.
Thanks,
Wolfman
When I have filled the rears to 46 you can feel the tread raised in the middle. At 52 you must have this problem in a huge way.....
Thanks for the info! While I love to have sustained 150 mph runs as well, I'll have to stick to something around 100mph in the US as I enjoy keeping my license. I assume that you also have to go down to Germany to go fast since the Netherlands are even worst than the US when it comes to speeding
Btw. I am using about the same setup as Schiznick 38F/40R regular air...
Wolfman
Last time however I took Steve from MBenzNL to Düsseldorf and on the on-ramp of the Autobahn my intercooler pump resulted defective as the supercharger shut down
Now I'll have to go over there again to test the new IC pump
You gain 3 to 5 lbs the hotter they get
Dino - what tire size (and brand) are you using?
I too have the SL65 19" rims on my SL55, and did a couple of track days with it at Watkins Glen. Lots of fun, and faster than the '89 Porsche 928 S4 I'd been driving on various tracks for about a dozen years.
I had found that a 'hot off the track' pressure of 40 psi with Michelin PS2 tires in size 295/30 X 18 (rear), 255/35 X 18 (front) was just right for that car/tire/size combo.
Thanks for the bit of further info.
PS2
The SL55 is surprisingly good on track. My last time out in the instructor group, I was matching one of the guy's Z06 times........ until the brakes gave up the ghost! Slowing 4000 pounds generate allot of heat!
I had the same issue with the brakes. Knowing I wasn't going to be pushing it very hard, as this was my 'retirement from track' drive, I put on a new set of Akebono ceramic pads F & R. Went completely through the pads, down to the steel backing plates in 2 days (about 200 miles) at 'the Glen'. I wished I'd have gotten a good set of track pads, even for just the two days!!!
Grazie for the tire size/brand info.
PS: Where in AZ? I spent '64-'68 at ASU in grad school.
