SL55/63/65/R230 AMG: Kleeman vs RENNtech
Appreciate any info.
Thanks,
Renntech does offer TCU upgrade which no one else does.
Software, intercooler cooling upgrade and air box will get you very close without digging into the engine.
If you want to go beyong, ported heads and turbos, along with larger intercoolers and heat exchangers will get you over 800HP.
The weak parts in this car is the drivetrain. The Gearbox is rated for a 1000 Nm, and it is generally accepted that it is not advisebul to exeed 1100 Nm. So even if the engine is cranking out 700 Hp. the torque is limited to 1100 Nm. ( the engine is capebul of 1365 Nm or somthing like that, at 715 Hp.)
The backside of this tuning is that the car is very hard to control, as you constantly are smoking your tires, even with LSD, also in the higher gears, if you try to use all this Torque. You will have the ESP flashing all the time.
I remember having seen a testdrive with the Brabus SL65, ( 715HP. 1100 Nm)
and it was nothing but wheelspin.
As a comparison, my 55 is hard to control, if the road is wet and the ESP is turned off.
Thanks Again
I had better reliability record with the latter,many problems with the former(cracking headers in 55,misfiring because of ECU in 65,LSD problems in SL).
Needless to say,next car will be done with Renntech...
May I ask what problems you had with the Kleeman LSD unit? I'm just thinking of that myself, since there doesn't seem to be anybody in the Chicago area who has installed the Quaif unit in SL's.
Thanks,
David
I'm not satisfied with the way it "locks",I suspect it's the reason car is unstable at accelleration.
Would not do it again....
Evotech & Renntech increases the torque from 1000 Nm to 1200 Nm, nothing more than 1200 Nm.
Evotech & Renntech increases the torque from 1000 Nm to 1200 Nm, nothing more than 1200 Nm.[/quote]
You are not afraid, over there, not a bit, are you. 1200 Nm, Uuh.
To my knowledge, the leading European tuners have taken back to aproxx 1100 Nm, because of too many incidents with Transmission damage.
How many 800+ Horsepower 65's are there out there?
Good luck, your car will be a SUPER beast after this....
That sounds like an interresting topic.
What is the max possible torque ??
How can the electronic help prevent gearbox failure ??
Is it possible to change the ratio of the gears ??
Can the shifting point ( motor rev.) be altered.
I'm just thinking now of the potential trap speed of our 4-door limo with such power, LSD and 305rears allied to lightweight 18s. Would likely cause many at the strip to faint.
On the issue of tires, how wide can we go at the rear? I'm OEM right now
18s are the way fwd if I change the beautiful 19s as they'll get me up the strip quicker than 20s. All go and no show is a 65 mantra.
I am also looking into shifting TQ up, not only to gain HP, but also to reduce wheelspin.
I am putting together several stages to go above what Kleemann and Renntech offer.
Stay Tuned.
