SL55/63/65/R230 AMG: What is the widest rim/tire combo possible on the SL?
Old Aug 18, 2007 | 12:43 PM
Deshapiro's Avatar
Looking
I tried to search the answer, but it was no help. Any input woiuld be appreciated.
Thanks,
David
Old Aug 18, 2007 | 04:24 PM
rbtronnie5's Avatar
You name it i've had it or got it...
9 front 11 rears is the typical set up...i have heard though of people running 9.5 up front with a different offset though.
Old Aug 18, 2007 | 05:42 PM
RoydRage's Avatar
SL55
Thanks,
David
9.5" on the Front with 255 Series tires
11" on the rear with 305 Series.... BUT... I would recommend 10.5" rears with 295mm tires... the 305's would stick out a bit... Some like that... I DON'T... You have to watch the offset also.
Best,
RoydRage
Old Aug 21, 2007 | 10:34 AM
filthyrichmitch's Avatar
Mainly the SL55 and E55
11.5 is possible in the rear but it needs to be 19's, 20's will rub under pressure.
Old Aug 21, 2007 | 11:01 AM
SLcharger's Avatar
SL55AMG, ML420CDI, E320TCDI
You can easily run 275 x 20 up front, and if you get your rear fender rolled a bit, you can run 315 on 11,5 x 20 on the back, without any rubbing problems.
That about as big as it gets, unless you are prepared to do some bodywork.
Old Aug 21, 2007 | 04:08 PM
Deshapiro's Avatar
Looking
Thanks for all the input. FWIW, I plan to get either a 20 x 10 or 10.5 for the rear, and a 20 x 9 for the fornt.
David
