SL55/63/65/R230 AMG: intercooler pump replacement.
Old 10-10-2007, 06:20 AM
Zod
Zod's Avatar
CLS55 2006, CLS 63S 2015
came across this thread while searching. Not sure how much it holds relevance, but it has pics!!
http://www.f150online.com/forums/sho...d.php?t=139146
check page 1 & 5 also has comments by a person claiming to be one of the designers
am still confused on the cobra pump and if it is the same one mentioned on here. IF it is still not sure it its better or not then stock or johson cm30
Old 10-17-2007, 09:19 AM
RoydRage's Avatar
SL55
Zod,
Yes I see what you mean, there is some confusion about the Cobra pump, claiming it flows less, and loses HP compared to a stock pump which I gather is the same as ours?
In anycase... Did you see the times these guys are turning?!?!!! 11.35's?
So you mean a these guys with their Pickup Trucks Are going to BLAST MY HEAP!!!!! EGADS!
Pulley and TB here I come
Best,
RoydRage
Old 10-17-2007, 09:50 AM
erdocslx2's Avatar
2016 s65 Coupe, 2021 GLE53C, 2015 S550
Here is the link for the cobra pump. This is not the lightning truck pump. You have to do some conversions. That converts to my numbers above. Or You can test it versus stock. which my test confirmes almost 4 times stock rate.
http://www.boschmotorsandcontrols.co...2002/index.htm
Old 10-17-2007, 10:21 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
any more info about the cobra pump. i sold my johnson 30 to get the cobra but what are the links to a "cobra" pump? i see a bosch pump on the link. is this the cobra pump? any more clarity is appreciated.
Old 10-17-2007, 12:12 PM
erdocslx2's Avatar
The cobra pump is a bosch pump. Howver pumps 3-4 x more water /minute. Here is the link to buy.
http://www.lightningforceperformance...ent-p-324.html
Old 10-18-2007, 12:40 AM
Jrocket's Avatar
E55
Same as the lightning pump,which is basically the same as the stock MB pump.So you just replaced your stock pump with the same pump.
Old 10-23-2007, 01:20 PM
  #32
anerbe's Avatar
C63S past: E90 M3 6M, w211 E55
Hmm....according to your link, it flow at 1200 dm^3/hr.
converting, it turns to 1.2 m^3/hr
converting again, it turns to 20 l/min.
stock is 14 l/min, which 14 * 3 = 42 l/min claimed, double the bosch pump.
the linked unit above is a bit over 50% more than the claimed OEM flow. however, we have not counted the performance curve at different pressures. i'm not certain of the system pressures, but the 20 l/min looks to be on the low restriction side of the performance curve.
Old 10-23-2007, 01:37 PM
  #33
anerbe's Avatar
oh geez,
i actually looked through some archives in mbworld.org
the pump you linked is 0 392 022 002. look at the performance curves
then look at this thread:
https://mbworld.org/forums/c32-amg-c55-amg-w203/206555-replacing-bosch-ic-pump-johnson-c030.html
the pump that was pulled off the 55k is 0 392 022 003, which actually has a better characteristic curve than the 002... i have the 003 on my desk right now, and the difference is that the 03 has a metal motor side housing, while the 002 has a plastic.
if you replaced it with the 002, you may be getting at best stock flow, or maybe a bit less. your gains are probably from a new pump opposed to a used pump.
Old 10-25-2007, 07:56 AM
  #34
Zod
Zod's Avatar
Originally Posted by anerbe
oh geez,
https://mbworld.org/forums/showthread.php?t=206555
Thanks for the info
Old 10-25-2007, 12:47 PM
  #35
erdocslx2's Avatar
I am ending the debate of what pump is on my car. I bought a new pump it should be here today. Unfortunately, I am recovering from emergency surgery so I can buy but can't install. LOL. Here is the link to what is going in mine. Plus I had a dual pass heat exchanger custom built so that will be going in soon.
http://store.summitracing.com/partde...5&autoview=sku
Old 10-25-2007, 01:03 PM
  #36
Zod
Zod's Avatar
I wish you a speedy recovery (inshalah). and await for when you are free to post up your new stuff
Quick Reply: SL55/63/65/R230 AMG: intercooler pump replacement.
