SL55/63/65/R230 AMG: Chirping noise - SL55 AMG
SL55 AMG (03); SL500 (98); BMW535 (08); Landrover LR2 (07)
Does anyone have any experience of a slight engine bay squeal when pulling away and / or accelerating somewhat hard between gears. I have been told that it might be the supercharger clutch and this was a rare but known problem on the 03's.
C63S coupe, X5M
Mine chirps on redline shifts, jerks a bit to. I like the jerk so I'm not sure I want to complain about it.
It can be fixed by the updated 07 clutch packs for the SC.
Fan belt?
I have an 08 SL55 with just 3200 miles and recently I too hear a chirping noise at cold start-up. It goes away after 5-10 minutes of driving. I thought it was one of the belts and gave them all a spray of WD-40, but that did nothing to stop the problem. Could this be the same thing (s/c clutch)? Mine does go away when the engine is "warmed up", and I can hear the sound when accelerating normally, presumably without engaging the s/c. There is no sound at idle. Any ideas?
SL55 Chirping
2007 SL55-AMG, 2006 Cayenne Turbo S, 1989 560SEC
Fan belt?
Your '08 SL55 should not be chirping during acceleration! That was a known issue on '03-'06 models caused by a slipping supercharger clutch. The chirp they are discussing occurs only during acceleration around 2000 rpm when the S/C engages, doesn't matter if engine is cold or hot!
A new S/C clutch pack design for '07-'08 cured that problem! My previous '05 had that annoying chirp every time the S/C engaged but now that I have an '07, no chirp!
Your engine's chirping problem is most definitely due to a loose belt which is evident by consistent chirping when idling after engine start but goes away when the engine warms up.
Do not spray WD-40 on your engine belts!
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Google or consult you MB service advisor about how to get that stuff off and get your belt tightened!
SL55
i have that chirp in my 03 , i hear it on take off when the gears switch. Never inquired to see the repair cost. Might move up a few years rather than put more cash in an 03.
sound 8 SL55 chirp
I have the same problem with my 55 on 02 plate.
I was told by the main dealer that they all do this to a greater or lesser
degree. They said it was supercharger belt slip, I get mine mainly pulling away.
They said there was no cure, but would not let me down.
C63S coupe, X5M
