Does anyone have a link to show and explain how to hardwire a Valentine 1 radar in a SL63?
Thanks in advance.
Thanks in advance.
Tie in to a wire in the overhead vanity lights. That is what I did. If you have done any minor wiring before it should not be a problem. It is easier done with the top down. We had to gently pry the header console off inorder to expose the wires. Be sure to tie into the wire that is only hot when your ignition is on. Im sorry I can't tell you which one that is but it was easy to find. Thats the best I can tell you. Good Luck!
Can someone confirm whether you can still use the cigarette lighter power source?
MJ50
Super Moderator
close
- Join DateJul 2003
- LocationMBworld
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drivebone stock E55 AMG
Liked:973 Times in 944 Posts
Quote:
yes u can...Originally Posted by mprsev
Quote:
Hi there,Originally Posted by hbluthi
which cables (colors) did you use for the hard wiring job?
Thank you!
