SL55/63/65/R230 AMG: How high (or low). SL55 030
Old Jan 19, 2009 | 10:56 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Love my car, but just too high. How much have you guys put your car down? I plan to do it via Star diagnostics, and previously, they just asked me "how low"? I measured the distance between the ground and the bottom of my front fender at 27.25", and the rear at 27.5" (sorry, didn't convert that to metric). (This would be the distance from the ground straight up thru the center cap, to just touching the bottom of the highest point of your wheel arch). I'm thinking probably 35mm front, 30mm rear? What' s your car measure or look like? Thanks for your help in this....
Old Jan 19, 2009 | 10:55 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
It s going to depend on the tires and wheels you have on the car. You are going to have to check your clearances when the car is loaded all the way down on each corner.
And with the wheel turned side to side.
Youre going to have to readjust it if you have any scraping problems after driving.
Its a lot easier to use the adjustable links so you can do the whole job yourself.
You can set it up and test it in the garage. Then when you think youve got it right, drive it a while and see if you need to readjust it.
Old Jan 20, 2009 | 12:39 AM
allenjdmb's Avatar
Thanks, but not planning on doing it with ....
the links. I think most folks here are using SDS or a box. And yes, I know it will vary. That's why I wanted to know what others height was at rest, and with the 030 PP wheel setup. Thanks for trying....
Old Jan 22, 2009 | 03:34 PM
allenjdmb's Avatar
So, everybody's car here is stock height?
Somehow I don't think so. Gimme some insight, or a picture, or some help if you can. Thanks.
Old Jan 22, 2009 | 04:39 PM
G_KATS's Avatar
SL 55 AMG
put 20inch wheels and the car will look alot lower.
Old Jan 22, 2009 | 04:58 PM
G_KATS's Avatar
SL 55 AMG
MY CAR WITH STOCK WHEELS ON
MY CAR WITH 20 INCH WHEELS
I DID NO LOWERING ....BUT BIGGER WHEELS ALWAYS MAKES CARS LOOK LOWER
Old Jan 22, 2009 | 06:20 PM
allenjdmb's Avatar
Thanks, but I did that with....
my SL 500, and it still had to be lowered. For me, yours is still too high. Not a bunch, but I still see too much "daylight". The reason for this thread is that the 55, in theory, should sit lower than the 500, and I"m wondering if the 030 suspension, with it's "Nurburgring" tuning, is lower than that. Thanks for trying though, it's more than anyone else!
Old Jan 23, 2009 | 02:39 PM
bosch man's Avatar
SL55 AMG
...the sl55 std look stupid!!!...mine on std rims is 25mm lower via DMS uk now it looks good!!!
Old Jan 23, 2009 | 05:58 PM
allenjdmb's Avatar
Hey thanks Bosch man!
That looks nice, not ridiculous, but much better than stock. I was thinking 25-35mm, so we're on the same page. Thanks again for the reply....
Old Jan 25, 2009 | 09:26 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Hi:
We do all our lowering through the STAR system. I will check with my tech to see how much we lowered my SL55, but I believe that 35-45mm is the right range. I will also measure where the fender is in relation to the ground. I am on 19" AMG wheels.
Here is a link to our MB/AMG page. There is a shot of my car at the lowest setting. Is this what you want?
http://www.veloceperformance.com/mercedes.htm
Old Jan 25, 2009 | 12:25 PM
allenjdmb's Avatar
Thenks...
I had looked at that and thought that was a good height, f and r. I was also thinking 35mm or so. Appreciate the replies, keep them coming--if you have pictures, post them!
Old Jan 26, 2009 | 06:36 AM
bosch man's Avatar
SL55 AMG
ingeneamg
..45mm you got to be joking?..look at mine and that is 25mm..why would you go any lower?Unless the USA version is higher than the UK model standard?
Old Jan 26, 2009 | 12:40 PM
Originally Posted by bosch man
ingeneamg
US cars are set up like SUVs...
Old Jan 26, 2009 | 10:55 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by IngenereAMG
Hi:
veloceperformance.com LOWERING PROGRAM! We now can electronically lower your ABC or Airmatic equiped MB or AMG. Prices start at $700. We can lower your ride height to wherever you want it! This service is currently only available in Arizona. Take a look at our lowered SL55 AMG.
For your information this type of service is availabe in a lot more states than ONLY ARIZONA I just scratched the surface &...
I have found (3) shops in CA (1) Arizona that will do this exact same lowering via Star Diag, they ALL CHARGE between $250-$300 out the door! Why the robbery? Your add states prices START @ $700
Old Feb 5, 2009 | 05:42 AM
John V.'s Avatar
Former Vendor of MBWorld
2007 CLK63 Cab
Adjustable Air Ride Lowering Links are fully adjustable so you set the vehicle to whatever height you like. For the SL and every other vehicle except the E & CLS there is no unbolting and the wheels don't have to come off. Simply pop off the stock Links and pop the fully adjustable 1's on. Really that easy!!!!
Old Feb 5, 2009 | 02:06 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Heh, apparently the car lowers itself up to 30mm above 60mph, what happens if you already have it lowered???
Old Feb 16, 2009 | 10:02 PM
xircom200's Avatar
SL55
G KATS is that a SL or a 4x4 ? That thing is High....
Old Feb 16, 2009 | 10:43 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
The lowering module I have is set to lower my car lower than the stock lowering settings every time I come to a complete stop and then raise it back up when in motion. It’s a cool lowering effect to have and it gets noticed.
I upgraded to the 030 shocks, but I didn't notice if they could go lower than the stock shocks. I can get measurements later..
FYI..my front tires are 1" taller than my rears as I'm trying different sizes.
I don't like the look of the rears as they are too low profile.
Here are a few pics..
Old Feb 16, 2009 | 11:07 PM
Fantasm's Avatar
Car Whore
havoc, havent seen you posting in a long time -- is your car done yet??
Old Feb 17, 2009 | 02:17 AM
Havoc's Avatar
Nope, not yet. I stopped the project for a while which caused a delay.
The 5.7L is still in Canada, but should return to Vadim's shop in a couple of weeks. The project keeps getting longer as I keep adding mods to my list.
Have patience my friend, I'm going for the ultimate 55K!!
Old Feb 17, 2009 | 08:35 AM
allenjdmb's Avatar
Hey Havoc...
do you have 245 or 255 on fronts? Looks great....
Old Feb 17, 2009 | 08:50 AM
Havoc's Avatar
Thanks Bro!
The fronts are 245/35/20, 26.8 Diam. x 9.8" Wide.
FYI..Michelin PS2's run a little larger than other tires.
