SL55/63/65/R230 AMG: SL65 handling
Also, what improvments could be made to the stock SL65 suspension to make it a better canyon runner?
Thanks for the input.
Tim
The SL65 is more of a GT car. That's not to say that it doesn't handle, because it does. But you have to keep in mind that all the electronic gadgets in the world can't totally hide that it is over 4000 pounds. The electronics also are part of the character of the car. The brake and steering feel have a bit of an artificial feel to them. Whereas the Porsche and Ferrari give you more feedback through the wheel and pedals.
The Ferrari may handle better than the Lamborghini, but the 4WD gives you heroic confidence and makes it almost impossible to put a foot wrong. While the steering doesn't have the feel of the Porsche and Ferrari, it is very good. I personally prefer the way te Lamborghini drives.
All of this is extremely subjective and cars are very much driver dependent. I have out run everything from Porsche GT3s, 360 CS, 430s, and Z06's at the track in my SL55. Most of today's car's abilities far exceed the talents and skills of the average driver. Just go drive variety of the cars you are considering and get a feel for what YOU like, and consider what your intended use is. Whether its an all around daily driver, or a weekend track day toy.... then pull the trigger. Take a drivers school, and go have fun!
.... and when you have exploited all the power that these cars have, and you are bored..... I can 'liven' things up a bit!
The SL65 can be pushed much harder into turns because the brakes are SOOO much better and the suspension is much stiffer on the SL65 plus the 65 has the limited slip. With wider wheels and tires (like the SL65 BLACK) the SL65 would be even better on a fast road course. I upgraded to the optional 10X19 rear wheels with 295 RE050 and this helped a little but 305 or even wider is really what the SL65 needs.
The SL65 does weigh 240 lbs more then the SL55 but not all of the extra weight is in the front with the V12 engine. The entire SL65 drive train is much stronger (20-30 lbs) and the huge SL65 brakes probably add at least 50-60 lbs. The SL65 limited slip and larger axles add around 20-30 lbs. The SL65 also has larger 19 inch wheels adds 10 lbs. The V12 engine is heavier by around 100 lbs but the extra 140 lbs is pretty evenly spread around the rest of the car and the stiffer suspension helps.
Not to say that either is on par with a Ferrari or a Porsche in handling because of the 4,400 lbs weight penalty. But with wider wheels and tires the race would be very close!
Had '07 SL65 and 997TT at same time back in Summer '06...enjoyed 65 more in twisties; no contest in tq deliv on fast fwys...997TT had poorly sorted PASM vs bumpy/camber change mtn twisties...PCCB pedal feel in twisties is one of world's best....SL65's brake pedal feel is one of world's worst among perf cars....in wet, would much rather have 65 brakes vs any PCCB/CCM
Agree, in twisties w/poss oncoming cars, etc, need to leave much room for error, in which case cars like latest AMG/P/F are far above most amateur drivers' driving skills....physical abilities of these cars w/a pro driver on a dry, smooth, empty track are different (and arguably academic) discussion....
That said, if face an unavoidable collision on a mtn road, would much rather have AMG active/passive safety engineering vs any F.....respect P's safety engineering, but view P as a couple steps behind AMG in safety
I can't comment on the other cars as I've never driven any of them.
I've owned a modded SL55 and now a modded SL65, IMO the 55 felt more exact when turning. The 65 handles relatively well especially when pushed but does not feel as exact as the 55 did. Running 305's on the rear has helped as well. Brake fade was a problem until I installed Renntech pads, it grabs better now and I'm not experiencing much if any brake fade.
My diemma is whether I keep the 65 with its insane acceleration or move onto another car that may not accelerate as well but may perform better in the canyons. I guess its time to rent the Porsche, Lambo, and Ferrari and take them up to the Bu for some spirited canyon runs, all in the name of research, of course.
