SL55/63/65/R230 AMG: S55 Suspension "Crashes" Over Potholes
The "thump" almost feels like there is something heavy loose in the trunk or something.
I spoke to my service manager and he said he heard similar things on a CL with ABC. They checked if everything was tight and it was. So it probably is the ABC and the chassis that interact with eachother like that on small bumps.
Then there are the rubber bushings in the suspension. 180k miles? You should go through the car and replace every bushing in addition to the tie rod ends. Those parts are so long gone. My 04 also had completely worn out front thrust and control arm bushings.
With 180k miles you likely need a large amount of suspension work. THe car is just getting tired. With the costs to do the work a newer car is the way to go.
This is where a car with standard suspension parts is far better. If I had to pay for that work it would have been 9k in part for some shocks and bushings. Owning these cars out of warranty is a bad plan. Either the car gets old and wiggly or you go broke replacing parts.
