SL55/63/65/R230 AMG: Finally Lowered my SL55
Old Feb 16, 2009 | 01:46 PM
speed doc's Avatar
2008 SL55
I have 295/30/20 in the back with no issues what so ever. Rims are 20x11 inches in rear. Toyo Proxes
Old Feb 16, 2009 | 01:49 PM
LWD SL55's Avatar
SL55
Speed Doc, nice look
Is your's lowered ?
I have a 20x10 in the rear.
Old Feb 16, 2009 | 01:52 PM
speed doc's Avatar
2008 SL55
Stock height. I went with the taller profile tires because of that. If you go 25's you have to lower the car or it looks funny. I wanted a beefier look to fill the wheel wells. Thanks for the compliments. I like the rims by the way, very modernizing for the car.
Old Feb 16, 2009 | 02:02 PM
LWD SL55's Avatar
SL55
Thank You !!!
Old Feb 16, 2009 | 02:04 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Are they the Toyo Proxes 4? Got any pics?
Toyo Proxes 4 are 26.9" tall and 11.7" wide which are a tad bit smaller than the Goodyear F1 Asymmertic 292/30/20, but good to know they fit!
I was also looking at Toyo Proxes T1R 305/30/20 which are 27.2" tall and 12.3" wide which are probably too tall and too wide.
Old Feb 16, 2009 | 02:24 PM
LWD SL55's Avatar
SL55
Im currently running Toyo Proxes T1R all the way around
Old Feb 16, 2009 | 02:26 PM
  #32
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Hi, does lowering the car change the ride quality, it's something I would
not like to loose, although I might get some 19 inch Carlsson wheels
without lowering.
Old Feb 16, 2009 | 02:35 PM
  #33
Havoc's Avatar
Cool! Do you like them? How is the ride quality?
Old Feb 16, 2009 | 02:46 PM
  #34
LWD SL55's Avatar
SL55
They ride very smooth, i like that fact that they are not noisy like other tires.
Old Feb 16, 2009 | 02:57 PM
  #35
URnext's Avatar
SL55 AMG
Originally Posted by bryanc4
i have 295's.. no problems.
+1 I have 295/25/20 without any issues on 10" width wheel. I would try to stay to close to the stock rolling diameter since our gears are tall enough already which is why 295/25/20 were my tire size choice for the rear.
To me the sidewall is pefect (when lowered). It really also depends what size the rim is (width) to avoid the "streched" look.
Old Feb 16, 2009 | 04:11 PM
  #36
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
I have Toyo TIR all around also. 255-35-20 in front and 305-30-20 in back. I run them on 20 Carlsson"s. Ther was a rub in front when I turned sharply but we shaved the strut bolt slightly and it eliminated the rub. If I hit a large depression I can hear a very slight rub, but nothing major. We checked with Carlsson before purchasing and this was their recommendation. Before , the tires looked stretched but the wheels looked great. Now there is more rubber under the wheel and the ride is better also. I should mention that with this set up the wheels are not as exposed on the sides, i.e. more protection.
Old Feb 16, 2009 | 09:53 PM
  #37
G_KATS's Avatar
SL 55 AMG
10 inch rear wheel ...... thats to skinny for this car .... u need 11 inch rear rims.
Old Feb 16, 2009 | 11:37 PM
  #38
Havoc's Avatar
I agree with keeping the stock rolling diameter, but all my rims bent and I had to replace all shocks so I rather a thicker sidewall.
I'm hoping that a taller tire will help with traction with the power I'm going for.
Originally Posted by BMS
I have Toyo TIR 305-30-20 in back.
Wow!! Got any pics? Do you know what the offset is?
Old Feb 17, 2009 | 02:06 AM
  #39
URnext's Avatar
SL55 AMG
I know what you mean
OT, is your motor at Vadim's yet to be installed? Progress?
Old Feb 17, 2009 | 02:25 AM
  #40
Havoc's Avatar
The 5.7L is still in Canada, but should return to Vadim's shop in a couple of weeks.
The project keeps getting longer as I keep adding mods to my list.
Have patience buddy, I'm going for the ultimate 55K!!
Old Feb 17, 2009 | 08:23 AM
  #41
sound 8's Avatar
Hi,just the man. I want to buy 19 or 20 inch rims for my SL55 and was thinking about Carlsson. However I want to just fit them without the need for
alterations. I see you had to modify, but I would probably put 285 tyres on.
Thanks!!
Old Feb 17, 2009 | 08:40 AM
  #42
BMS's Avatar
BMS
2018 C63 Sedan
The mod was very minor. The top strut nut just needed to be filed slightly. We thought originally that the plastic liner might have to be cut but that was not the case. I still like the Carlssons' very well. My second choice were the Rentechs' as I also wanted light weight wheels, not boat anchors. Got a good price through Billy at Motorwerks of Michigan. 1-268-668-6793.
