SL55/63/65/R230 AMG: any 1 intalled smartTop?
Old Jan 21, 2010 | 10:16 AM
Benz-O-Rama's Avatar
I just purchased the one SPIKES was selling, in the classifieds. Should be here today or tomorrow. I'll try to pop it in this weekend.
Old Jan 24, 2010 | 11:00 PM
I installed mine this afternoon. It's not quite as easy as the instructions make is look. I believe the pictures in the instructions must be from an SLK and not an SL. My wiring harness did not have any slack to it to operate. I had to completely remove the panel that goes from the door jamb all the way around to that cubby, just to get at the wires. I could not even tap into the ground wire that they suggest. I had to run my own wire and ground it to a different part of the chassis.
But, once in, it works as advertised. Pretty cool
Old Jan 24, 2010 | 11:04 PM
E55MKB's Avatar
96 P993T, 00 E55, 09 SL63
Exactly, the ground wire tap as per the instruction is impossible on my SL63 without taking off the panel around the junction box hence ended up tapping ground from different location. Other than that it is pretty straightforward.
Old Oct 6, 2011 | 03:44 PM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I believe mine is also installed in the footwell area, but the new instructions are in the rear bin, does anyone know if you have to have an updated version to install there? I am having troubles with my lomo M1 and think that this may be the cause
Old Oct 6, 2011 | 03:51 PM
The SmartTOP module is definitely not in your footwell. It should be installed in the passenger side cubby compartment. Well, underneath of that, anyway....
Old Oct 6, 2011 | 05:27 PM
NEMES1S's Avatar
II am fairly sure that's where it is, and works fine.
Old Oct 6, 2011 | 06:21 PM
  #32
NEMES1S's Avatar
sorry, tried to type that on my phone. Mine is in my footwell for sure and it works just as it should, wonder what instructions I used.
Old Oct 8, 2011 | 01:20 AM
  #33
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
I also have the mod4cars one installed in my SL55 for last 3 years it was very easy to install.
Old Oct 8, 2011 | 10:50 AM
  #34
NEMES1S's Avatar
I am talking with the guys that sell them to figure out what the story is, I need to tear my interior out again to figure out what number is on my box.
Old Oct 8, 2011 | 04:10 PM
  #35
Pomppe's Avatar
SL 55 AMG 2003
I bought a smart top box from Kleemann 3 months ago. 20 min. installing time.
By the instructions, the box was placed by the fusebox under the storage box behind the the passenger seat. By following the instructions, You get the power and ground from the fusebox, no wiring under the floor mat or door sill.
Old Oct 9, 2011 | 11:47 PM
  #36
mcw's Avatar
mcw
2008 SL 63 AMG R230
have smartop done to my 2008 SL 63 R230, works well
https://mbworld.org/forums/sl-class-...-03-sl500.html
Old Oct 10, 2011 | 02:58 PM
  #37
nsxguy's Avatar
a few cars, few bikes,04 SL55
Just installed mine, everything works accept the chirp siren when activating the remote. Can any body please show me how to program this feature please???
Old Oct 10, 2011 | 11:42 PM
  #38
NEMES1S's Avatar
insert key, turn to accessory position, then hold the han up button for 5 seconds and you should be able to scroll through the gauge cluster display until you see the top info, you may need to double check the manufacturer website for instructions beyond that.
Old Oct 11, 2011 | 02:08 PM
  #39
nsxguy's Avatar
Thanks NEMES1S will give it a try this weekend
Old Jan 11, 2012 | 10:03 PM
  #40
MYSL55AMG's Avatar
SL55 AMG
smart top
Hey guys
Just bought the smart top, and wondering what is the range to operate the roof top?
I am planing on installing the unit myself, has anyone have the manual or procedure advice on doing this mod on a 2003 SL55 AMG?
Old Jan 11, 2012 | 10:06 PM
  #41
NEMES1S's Avatar
If you go to mods4cars.com they should have instructions you can download, there is also a good write up on here if you search for it. They work awesome!
Old Jan 11, 2012 | 10:18 PM
  #42
Originally Posted by MYSL55AMG
Hey guys
The range is the same as whatever your keyfob lock/unlock is.
Install doc is on their site. Wasn't that hard....
Old Jan 12, 2012 | 08:33 AM
  #43
jrgator's Avatar
ML63, ML320
I just did it. Great mod, and in particular I like being able to raise and lower the top while driving.
Be sure to look at the short video on their site. The bus can be a little difficult to get out, and look closely at how it is taken apart. It must be taken apart to get the connections out to locate the correct one.
Old Jan 12, 2012 | 09:51 PM
  #44
sl65amg2008's Avatar
2008 SL65, 2006 SLK55(sold)
Smart Top...Factory Option???
I am just curious about the Smart Top Option. Was this option or something similar offered standard on SL or AMG models. My 2006 SLK55AMG had something very similar if not identical from the factory. I ordered the car through my dealer and I could open and close the roof with my key FOB from across a parking lot. Similar to what the videos show on Mods4Cars. I never tried it on my SL65 so I don't know if it has this option. Car is in the shop now so I can't test it.
Old Mar 21, 2012 | 10:27 PM
  #45
UNSTPABL's Avatar
SL 55
New to the forum an need help please!!! SL55
Hey guys, can someone please tell me where or who can install my smart top module? I am not handy and have massive hands that break everything. I am in NY. Thanks in advance for helping me!
Old Mar 21, 2012 | 10:30 PM
  #46
NEMES1S's Avatar
It is really simple if you attempt it on your own, took me about 15the minutes total. I would suggest if you do it on your own, ground it to the bolt on the lower right corner instead of tapping a wire, easier and doesnt cut any more factory wires than absolutely necessary
