SL55/63/65/R230 AMG: 030 Package
- 19" wheels from SL65
- front facia from SL65
- brakes (the rotors are different size and material I suppose, are the calipers the same? anything else on the braking system different?)
- LSD
- some interior differences (what exactly here anyways?)
...am I missing anything? suspension differences maybe, anything else?
My questions are:
- the thing I think matters most in the 030 package is the LSD, if that's the case can we upgrade to an 030 LSD, or opt to go with a quaiffe or the like from the aftermarket?
- what years was the 030 option available for the SL55? Mine is an 2003 so I'm guessing the 030 option was available on later model years, I didn't know about the option when I was looking for SL55 cars ...
- about any sort of performance tuning advantage; if the ECU gets an aftermarket tune the that would negate any advantage of the 030 delimited ECU correct?
Keep in mind that yes, it was only offered later in the game, and less than 10% of SL55 cars had 030. I'm really surprised how many people on the street know the difference. It's probably the spoiler.
We can give them more power, as well as completely remove the limiter. Since the suspension is more performance tuned, and the brakes are better, it really makes a nice package.
If you're registered at the Private Lounge you can see the spec sheet:
http://www.mercedes-amg.com/privatel...8&d=1141781256
- How would I get a "Nurburgring tune on my ABC? What's the difference AND would it be worth it?
- as for LSD, I think a quaiffe would do the trick there
- speed limiter: aftermarket performance tune the ecu and get rid of that in short order
- interior: don't really care, regular AMG is fine, less features, gadgets, and gizmos the better
- brakes: 030 would be nice but the standard AMG is should be able to perform very well with a good set of pads and factory rotors, caliper and rotor size difference will not make a difference unless your running the car on a circuit for hours at a time putting substantial heat out, rather a good fluid and pad choice would make the most impact in braking performance overall....and although reducing unsprung weight does help in terms of 2pc vs. 1 pc rotors, the car is not a race car so it's not absolutely critical...
....any thoughts on the above?
