Anyone run 255/35-20 and 285/30-20 tires
Subscribe
May 5, 2009 | 05:27 PM
Which brand?
Any rubbing on full lock?
Is your car lowered? How much?
Reply 0
May 5, 2009 | 09:00 PM
If you have 20s, they should be at least 10.5 rears, you should have 305/25 on them.
If you have 8.5 to 9.5 fronts, you should have 255/30 or 245/35. The 30s are very low sidewall. The 35s are more normal sidewalls and they will fit.
But 255/35 wont fit. They are too high. they wont clear the upper arm.
Reply 0
May 5, 2009 | 10:00 PM
Thought so. For the rears, I am looking at 10in rears. The best I can fit on them is 295/25, but am worried it is too thin. I can't bump up to 285/30 or 295/30 as then the sidewalll will be too high compared to the fronts.
Reply 0
May 6, 2009 | 01:27 PM
Raptor- I am runnning 245/35 in front and 285/30 in rear, but I am going to 295/30 when I need tires. It looks like a have enough space in the fenders to go, it might be high but i know others have used this size..
Reply 0
May 6, 2009 | 01:48 PM
I am running 255/30 fronts and 305/25 rears in 20", Pirelli PZERO Nero.
-m
Reply 0
May 6, 2009 | 02:31 PM
What is the offset of your 11" rear? Thanks much!!
Reply 0
May 6, 2009 | 03:14 PM
Quote: What is the offset of your 11" rear? Thanks much!!
ET35 but I'd like to note that I run a hubcentric ring because in spite of their cost, the U/Ls are not hubcentric.
-m
Reply 0
May 6, 2009 | 03:26 PM
I run 245/35 in the front and 295/30 in the trear. 20 inch rims. They are 11inch width in the back. No issues what so ever. Toyo proxes 4
Reply 0
Explore
May 6, 2009 | 07:25 PM
Interesting...what is your rear offset?
Reply 0
Subscribe
Currently Active Users (1)
