SL55/63/65/R230 AMG: *** 55 Kompressor Heat Spacers Specials ***
Old May 11, 2009 | 06:43 PM
Vadim @ FD's Avatar
S600TT, R350
Ladies and Gentlemen:
With summer heat quickly approaching, I would like to introduce the May Special on our intake manifold heat spacers. Our heat spacers isolate intake manifold from cylinder head, reducing heat transfer from the engine block and thus heat soak.
Intake manifold temperatures decrease on average 20-30F. Reduced intake air temperatures help 55s produce more consistent power in hot weather.
We offer both upper and lower sets. Upper set can installed very easily by simply removing stock surge tanks. Lower set requires removal of the blower and is highly recommended when throttle body upgrade is performed.
Upper set - Regular $289, on Special $189 ($100 off)
Lower Set - Regular $289, on Special $189 ($100 off)
Both Sets - Regular $578, on Special $359 ($219 off)
Old May 11, 2009 | 08:24 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
What do you use to seal the new spacers?
Old May 11, 2009 | 08:29 PM
Vadim @ FD's Avatar
S600TT, R350
Factory gaskets.
Old May 11, 2009 | 09:28 PM
BeltFedBob's Avatar
Got it, one on top and one on the bottom. Any issues with the belt?
Old May 11, 2009 | 09:37 PM
Vadim @ FD's Avatar
S600TT, R350
No, belt is ok.
Old May 11, 2009 | 09:56 PM
BeltFedBob's Avatar
Thanks for the info.
Old May 12, 2009 | 05:18 PM
Sunir's Avatar
SL55 AMG
Vadim; am I correct in thinking that you have these phenolic spacers in two different colors? the green and black? the first two are the uppers and the bottom two lowers, each in respective colors?
Old May 12, 2009 | 06:16 PM
Vadim @ FD's Avatar
S600TT, R350
Black are gaskets, green are spacers.
