SL55/63/65/R230 AMG: Do all 03 SL55s come with XM radio? How can you tell?
Old May 14, 2009 | 09:16 AM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Going to look at a car, wondering if there is a tell tale way to see if it has xm radio before I get there. What can the dealer look for if it has it?
Any help is greatly appreciated,
Michael
Old May 14, 2009 | 09:55 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Michael
What year? If it has Sirius/XM it will have the antenna mounted in the center of the trunk.
Old May 14, 2009 | 10:16 AM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
I believe the only option was a sirius tuner. It was a option. I dont think there was many. Its very expensive from mercedes.
#1, have the dealer pull up the origional option list of the car, then look for the antenna to see if they had one installed later.
Old May 14, 2009 | 11:10 AM
InTheBenz0's Avatar
if it doesn't have it, is it expensive to add? Or should I just buy a sirius radio.. for example one called Sirius One.. looks like a mini beeper/radar detector, and use that. Got it for $24 shipped on Amazon.
Old May 14, 2009 | 03:05 PM
okbarnett's Avatar
I dont know how much the mercedes sirius add on is. But probibly $500 to $1000.
You can use the sirius add on and run it thru the fm , but it just modulates the signal into your fm tuner.
Old May 14, 2009 | 03:28 PM
InTheBenz0's Avatar
does this let u use the headunit/nav to control the name of stations, etc
Old May 14, 2009 | 07:20 PM
mikesSL55fla's Avatar
sl 55 amg
Sat Radio
I have an 04 and it didnt have it so I bought the sirius kit and had it installed.
Mounted the head unit through the grill on top of the dash so as not to drill and placed the antenna under the drives top vent outside and you cant even see it.
You will have to set your radio to a station and have it run through the radio/nav command. It works fine and causes no issues to me.
Old May 14, 2009 | 08:01 PM
InTheBenz0's Avatar
did mercedes do it? How much was the kit and any links?
and how much was it to install
Old May 14, 2009 | 11:19 PM
okbarnett's Avatar
If you use the sirius add on, No you dont have anything on the screen. Just the fm station, The only way you can get that feature is to have a factory unit.
You are looking at something like a sirius starmate.
I used one of these for the first couple of months I had my car. Then I did my whole system, see this :
https://mbworld.org/forums/sl55-amg-...eo-system.html
Old May 15, 2009 | 08:56 AM
LOVEMYBS's Avatar
Michael
I had MB install Sirius in my E55. It runs through the nav. and looks/acts like it came from the factory. Kit and install was $1,000. Personally, I think Sirius sucks and I won't renew my subscriptions when they are due. I'm back to CD's because I can choose what I'm listening to.
