SL55/63/65/R230 AMG: Convertible top won't open...Help!
Old Jun 12, 2009 | 10:14 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Before I send this to the dealer, I was wondering if someone might have fix...
I keep getting "close trunk partition" message whenever I try to open convertible top. Every time I check the trunk and the trunk partition is in place...Isthere contact not meeting or a switch not working?
Old Jun 12, 2009 | 10:29 PM
sun72's Avatar
SL55 AMG
I suspect its a contact not meeting...are the pins that hold it in place fully intact? I would check to see if either of them are bent before I send it to the dealer.
Old Jun 12, 2009 | 11:47 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
the switch is on the right (pass) side latch, which is the spring loaded latch to the rear that the trunk cover clips into when you close it and 'latch' it in place.
make sure it is latched in all the way. Or block it closed with a item; piece of wood/ plastic, then see if it will correct it.
Old Jun 13, 2009 | 08:11 AM
sun72's Avatar
SL55 AMG
I'm not sure if this will help, but here's a tech sheet that maps out all the function prerequisites and the communication flow for the vario roof...
http://www.mercedestechstore.com/pdf...2001-24-02.pdf
Old Jun 13, 2009 | 12:53 PM
AMGfan's Avatar
FIXED!!!!!
Took it to my tuner shop...they came in on a Saturday for me.... The plug to the partition switch was unplugged. There was some work in the back panels and apparently the person putting the car back together forgot to plug in that switch.
Old Jun 21, 2009 | 09:42 PM
percykwong's Avatar
13 S550, 10 S550, 08 GL550, 05 SL65, 97 SL600, 09 E63
That problem drove me nuts for a while as well, until i realized the trunk partition was that little flap thing. *hah*
Old Feb 18, 2012 | 07:39 PM
150shot's Avatar
08 CLS63, Honda Accord, 04 911
Reviving this one...just got car back from dealer from warranty work including the Trunk struts...now getting the "Close trunk partition" when trying to put top down..
Of course I didnt try this at the dealer , and not wanting to go back ..I know work has been done back there hopefully a quick fix? any other suggestions?
Old Feb 19, 2012 | 08:06 AM
carlsturm's Avatar
thx for posting the tech sheet
