SL55/63/65/R230 AMG: WOW ECU reset!
Old Jun 28, 2009 | 10:56 AM
1badassbenz's Avatar
Mercedes
Will this effect or remove any ECU software? I have the renntech ECU upgrade and dont want to lose that.
Old Jun 28, 2009 | 01:07 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Does it matter if the car is cold or hot or sitting over night ? So just go in and reset that bad boy ?
Old Jul 3, 2009 | 08:47 PM
Brent72's Avatar
SL55
Tried this out for the first time tonight and all I can say is WOW!!! It was like a different car when I mashed the gas pedal. Thanks for passing along this wonderful little secret.
Old Jul 3, 2009 | 10:06 PM
mikesSL55fla's Avatar
sl 55 amg
I have a sprint booster will this help or make things worse as far as the booster goes??. The booster is suppose to give you better throttle response.
Old Jul 4, 2009 | 05:49 AM
Mercedes
Originally Posted by jturkel
this is perfectly safe to do. it will not hurt anything. after about 250-300 shifts, your car learns your driving style and tends to shift and provide power the way that is most comparable to your driving style. this simply resets this and results in more raw shifts and better throttle response. i do this all the time on my car as to many many members here with modded cars.
nothing shows up on the dash. at all.
EDIT: https://mbworld.org/forums/w211-amg/...set-works.html
you will notice a difference. you can wait longer too. it works fine for me after 2 minutes. i used to wait 30 minutes until i found out 2 minutes works just fine.
Old Jul 4, 2009 | 07:25 AM
Quadcammer's Avatar
96 and 08 911 turbos
no, it will not remove or mess with any aftermarket tune info.
It basically just resets the trans/throttle adaptations to zero.
Old Jul 4, 2009 | 10:36 AM
  #32
Mercedes
Thanks I will give it a try
Old Jul 4, 2009 | 01:24 PM
  #33
sl 55 amg
WOOO HOOO
Thanks Speed Doc it works great..!!!
Old Jul 4, 2009 | 02:30 PM
  #34
G_KATS's Avatar
SL 55 AMG
ya it worked .... but it goes back to normal after driving in the city for awhile .
Old Jul 4, 2009 | 03:33 PM
  #35
sjcsl55's Avatar
04 SL55 AMG
Ya, I think it recognizes your driving habits after 200 - 300 shifts...
does anyone know if this affects sport mode? Does sport mode also auto adjust to your driving habits, or is the throttle response, etc. hard coded?
Old Jul 4, 2009 | 11:32 PM
  #36
sl55amg2004's Avatar
2004 SL55 AMG
How do you reset the computer after an oil change has been performed? Thanks.
Old Jul 5, 2009 | 09:19 AM
  #37
Quadcammer's Avatar
they both auto adjust, but with different underlying assumptions about how early to shift
