SL55/63/65/R230 AMG: WOW ECU reset!
Old Jun 24, 2009 | 09:53 AM
speed doc's Avatar
2008 SL55
WOW ECU reset!
I was reading a thread on here about cars feeling a little sluggish and that resetting the ECU would help. Well I did the ECU reset protocol yesterday and wow it awoke the beast! I drive my car in trafffic regularly so I guess it got trained into slow poke mode. It feels like a different car, crisp throttle response, revs faster, etc. I'm just amazed. This forum is a wealth of great knowledge. Thanks Guys.
Here is the sequence just in case anyone is interested.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Enjoy!!!!
Old Jun 24, 2009 | 10:22 AM
bigben320e's Avatar
CLS63 Designo Edition, Hyundai Genesis 3.8 , Veloster Turbo, CLS500(Sold), E320 (SMOKED) R500 (Sold)
Enjoy!!!!
I will try this out. Do you have a close-up on those rims? I would like to see one.
BTW- What a coincidence, you drive a SL55, and have 55 posts on here! LOL.
Old Jun 24, 2009 | 10:34 AM
speed doc's Avatar
2008 SL55
Sure, I'll dig some up. They are 20 inch MHT LLC'S. Great wheel and very strong and durable so far.
Old Jun 24, 2009 | 11:11 AM
Sunir's Avatar
SL55 AMG
I gotta try this...people have been raving about this on the W211 E55 forum!
Old Jun 24, 2009 | 11:27 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
What you are resetting with this procedure, is actually the throttle bodies. This tends to help responsiveness.
Rock on!
Old Jun 24, 2009 | 12:01 PM
speed doc's Avatar
2008 SL55
That makes sense Dino because the car feels incredibly more responsive.
Old Jun 24, 2009 | 12:33 PM
FLSL55's Avatar
SL65
You turn the key one click or two?
Old Jun 24, 2009 | 12:50 PM
speed doc's Avatar
2008 SL55
One click or just before it goes to the starter position.
Old Jun 24, 2009 | 12:56 PM
Brent72's Avatar
SL55
Thank you for this piece of info. I'll definitely be trying it out on my 55.
Old Jun 24, 2009 | 12:57 PM
FLSL55's Avatar
SL65
What do you mean by the starter position? Do you mean the car will start? Or do you mean the second click is the starter position and the third is the car actually starting.
Old Jun 24, 2009 | 02:19 PM
speed doc's Avatar
2008 SL55
The position just before you start the car ( the position the key is in when the car is running, that may be a better explanation) Hope that helps.
Old Jun 24, 2009 | 02:24 PM
FLSL55's Avatar
SL65
Maybe you should update the original post to say the second click.
Old Jun 24, 2009 | 05:02 PM
sjcsl55's Avatar
04 SL55 AMG
Position 0 is the "off" position, position 1 is the "acc" position for accessories, position 2 is the "on" position, when the car is in use, and position 3 is the "start" position, used when starting the car.
Old Jun 25, 2009 | 01:10 AM
G_KATS's Avatar
SL 55 AMG
if i do this, will it reset my KM for service A back to zero ???
Old Jun 25, 2009 | 02:13 AM
sjcsl55's Avatar
04 SL55 AMG
no, it only affects the throttle response part of the ECU... resetting your service timer is done using a different procedure.
Old Jun 25, 2009 | 05:08 PM
cal1's Avatar
SL55, ML500 & Acura TL
Rock on!
Would this make sense to do on a modded ECU? I'm running an 80mm TB also.
Old Jun 26, 2009 | 02:27 AM
G_KATS's Avatar
SL 55 AMG
i tried doing this today and nothing came up ....??? i drove the car and it felt the same too me
does somthing show on the dash saying ECU reseted ??? let me know thanks !
Old Jun 26, 2009 | 02:45 AM
jturkel's Avatar
02 C32 AMG
this is perfectly safe to do. it will not hurt anything. after about 250-300 shifts, your car learns your driving style and tends to shift and provide power the way that is most comparable to your driving style. this simply resets this and results in more raw shifts and better throttle response. i do this all the time on my car as to many many members here with modded cars.
nothing shows up on the dash. at all.
EDIT: https://mbworld.org/forums/w211-amg/...set-works.html
you will notice a difference. you can wait longer too. it works fine for me after 2 minutes. i used to wait 30 minutes until i found out 2 minutes works just fine.
Old Jun 26, 2009 | 11:17 AM
FLSL55's Avatar
SL65
Jturkel,
Your method differs from all the others I have seen on this board including Speed Doc's on post #1 above.
Old Jun 26, 2009 | 11:20 AM
cal1's Avatar
[quote=jturkel;3594054]this is perfectly safe to do. it will not hurt anything. after about 250-300 shifts, your car learns your driving style and tends to shift and provide power the way that is most comparable to your driving style. this simply resets this and results in more raw shifts and better throttle response. i do this all the time on my car as to many many members here with modded cars.
Thanks a bunch, I am going to give it a try. I had thought that because I generally drive like a madman or lets say "spirited" that it might not do much, but nothing to lose only to gain.
Old Jun 26, 2009 | 01:35 PM
jturkel's Avatar
02 C32 AMG
Originally Posted by FLSL55
Jturkel,
edited my post. it was late and i posted it in the wrong order. check out the link.
Old Jun 27, 2009 | 01:16 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Are this ECU Reset procedure stickily to the 55K Cars or to any MB cars ? I have the SL&S500
Old Jun 27, 2009 | 01:20 PM
jturkel's Avatar
02 C32 AMG
should be any car
Old Jun 28, 2009 | 12:33 AM
laitsabr's Avatar
2005 AMG G55
Worked for me
Wow! It certainly worked on my 06 E500 wagon (stock).
Many thanks for giving me a "newer" car!
Old Jun 28, 2009 | 10:30 AM
Fantasm's Avatar
Car Whore
works for me as well, and used to work on my sl55 too.
i dont even wait the 2 minutes after wards. i turn it off, pull the key out, then put it back in and its done.
